Function call does not evaluate numerically inside a for() loop
Function call does not evaluate numerically inside a for() loop - Messages
#21 Posted: 4/24/2018 6:52:06 PM
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Hi Jean,
I get an error running your worksheet at variable "User".
I also managed to come up with stable solver for both neutral axis depth "na" and neutral axis rotation angle "alpha". Problem is it can take up to 20 seconds per single solution and i potentially need to run it ~50 times. Any pointers on speeding up function calls?
Thanks!
formulaR8.sm (282.02 KiB) downloaded 1193 time(s).
#22 Posted: 4/24/2018 11:53:04 PM
Hi Jean,
Thanks!
I lost track of the project as finally the bilinear interpolation solves for both mutually.
Pretty easy to construct the data table wrt "na" & "alpha". Try yourself, if not sure,
please give me the respective ranges. The bilinear data table needs not be square.
It can be rectangular horizontal/vertical.
Cheers Alex ... Jean
Project_0 Biaxial Bilinear [jmG] Copy.sm (115.32 KiB) downloaded 1042 time(s).
#23 Posted: 4/25/2018 12:21:52 AM
... an otherwise bi-linear demo.
Bi-linear linterp interpolation has the virtue of quadratic.
QuadraticSplineCreateMesh.sm (15.59 KiB) downloaded 1209 time(s).
