Where to find the SMath Studio documentation/help if I want to learn SMath?
Where to find the SMath Studio documentation/help if I want to learn SMath? - Lack of documentation/help in SMath Studio? - Сообщения
#1 Опубликовано: 15.10.2024 16:05:46
Cornel
Cornel
2 сообщений из 78 понравились пользователям.
I see that SMath Studio has no documentation. So without a documentation behind which describes all the functions which are implemented in SMath Studio and on which user can use them, and also on which user can learn how to use these functions, how I can learn SMath Studio? Without such a documentation user does not know what functions are existing and can be used in SMath Studio...Without such a documentation and example user does not know how to use even the existing functions in SMath Studio...
Seems that SMath studio does not have any help to support the user in learning SMath Studio and what can be done with SMath studio, what are the capabilities of SMath Studio.
I saw that some users wrote a book or a tutorial having some examples included in these, but there is no official documentation describing the functions and some example on how to use these functions...
Look at Mathcad Prime help/documentation for example:
Показать спойлер
moderator: screenshots moved in the spoiler to keep the page readable
#2 Опубликовано: 15.10.2024 17:36:01
Cornel
Cornel
Or I can rely on the fact that all Mathcad Prime functions can be used also in SMath Studio? (the syntax is the same in both?)
#3 Опубликовано: 15.10.2024 19:15:34
566 сообщений из 1 339 понравились пользователям.
In fact, SMath has a documentation which is called Interactive SMath Handbook.
You can download it from Tools>Plugins>Interactive Books, and make it default.
Then you can reach it by clicking Blue Book icon with question mark at toolbar.
#4 Опубликовано: 15.10.2024 20:14:12
Cornel
Cornel
When I try to download Interactive SMath Handbook then SMath is closing/crashing. And when I run again SMath Studio, the interactive SMath Handbook is not installed.
#5 Опубликовано: 15.10.2024 21:25:25
1 431 сообщений из 2 902 понравились пользователям.
Same error as the Maple Plugin. Definitely a bug in the latest SMath Studio code (hard crash on extension installation).
#6 Опубликовано: 15.10.2024 21:48:29
Cornel
Cornel
Somebody has any idea then when this issue will be solved?
#7 Опубликовано: 17.10.2024 00:40:21
Cornel
Cornel
Does anyone know if this issue has reached the owner of SMath and in how much time this probleme will be solved?
#8 Опубликовано: 17.10.2024 01:38:50
1 262 сообщений из 2 188 понравились пользователям.
You can download the Interactive Handbook from the [url=smath.com:8443/!/#public/view/head/handbooks/Activebook/activebook]SVN repository[/url]
Just download all files in the Activebook directory and open contents.sm just like an ordinary worksheet. Navigate the links using Ctrl-Click.
#9 Опубликовано: 21.10.2024 16:20:00
Cornel
Cornel
Thanks Martin.
Anyway, taking into acoount on Davide Carpi's comment as well, this bug with the bad or not loading properly plugins in the latest SMath Studio code should be reported to the owenr of SMath,and hope to be solved this bug in the next update of SMath code...
#10 Опубликовано: 22.10.2024 13:41:07
Cornel
Cornel
Thanks Martin.
Ok, I see today than an update was made for SMath Studio and I was able to install Interactive SMath Handbook from Tools>Plugins>Interactive Books without crashing or closing of SMath Studio.
Thanks.
#11 Опубликовано: 23.10.2024 22:53:35
⚜ Kenny Lemens, P.E. ᵂᴵ
80 сообщений из 175 понравились пользователям.
... how I can learn SMath Studio? Without such a documentation user does not know what functions are existing a...
Greetings!
   I fully understand your frustrations. As such, I took the initiative to compile a keyboard/keypress sheet for users to help navigate the program. The tricky part is knowing that certain functions only exist if you have certain plugins installed.
https://en.smath.com/forum/yaf_postst23271_SMath-Keyboard-Shortcuts.aspx
   You can use the "Function..." from the Dropdown of the 「Insert」 menu in the menubar (i.e., 「Ctrl」 + 「E」) to review all (or at least most) functions currently loaded into your program. Other then that, you can take advantage of https://en.smath.com/forum/yaf_topics32_Extensions.aspx to view documentation on the various plugins.
   Just an FYI, the two people on this thread (Davide Carpi and Martin Kraska 「mkraska」) are some old-pros when it comes to this software; we all have some decent authority and working relationships with the owner. You are in good hands if they are helping you through an issue/question.
   In conclusion, I'll leave you with this post from 3 years ago:
ElSid,
Ctrl+Shift+K does already work in SMath... are you talking about just adding that to the documentation so it's not a secret anymore? It does kind of remind me of playing video games as a kid and having to discover and memorize the different undocumented "cheat codes" that each game had.
Jason
May this be of Good Help;
ioan92 24.10.2024 00:08:00
