Beta: SMath Studio 0.99.7769 (09 April 2021)
Beta: SMath Studio 0.99.7769 (09 April 2021) - Сообщения
#21 Опубликовано: 10.04.2021 05:49:28
Any suggestions on how the text is displaying in controls?
CheckBoxList Region fixed now. Please update it using Extensions Manager.
sergio 10.04.2021 10:38:00, Jason McCool 10.04.2021 11:29:00
#22 Опубликовано: 10.04.2021 11:45:32
Jason McCool
Jason McCool
You rock, Andrey! Thank you - not just for this quick fix, but also for your dedication to this whole project.
#23 Опубликовано: 13.04.2021 03:30:15
Actually one thing we really want is bold and italic font functions to work with linux.
Sign-in option has secondary priority compared to this at the moment if you ask me.
Yesterday I've spent some time on the issue regarding font style (bold/italic) in Linux and the only information I've found is this bug in Mono: https://github.com/mono/mono/issues/17314
Tried to use suggested workaround, but it seems it is not applicable for us because of too slow performance.
Here is a version of SMath Studio with my attempt to use workaround: http://smath.com/file/2wQhP
It works, but it is extremely slow - almost impossible to work with real worksheets.
Will see, maybe another solution will be found in future.
#24 Опубликовано: 13.04.2021 19:24:56
I will definitely try your solution.
If it won't be applicable, so be it.
After all this is drawback of mono.
We accepted our fate. (swh)
Edit: Your solution works with fonts.
But it has very slow performance indeed.
Not "not usable" level but I won't prefer to use this daily.
I will keep this version just for print purpose.
Thanks Andrey.
Andrey Ivashov 14.04.2021 02:52:00
#25 Опубликовано: 15.04.2021 16:19:45
I did it!
Please download https://en.smath.com/file/UhVpV and replace SMath.Drawing.dll from the distribution package with downloaded one.
Everything should work fast enough! Will include this workaround into the next build.
overlord 15.04.2021 16:36:00, Вячеслав Мезенцев 16.04.2021 01:01:00
#26 Опубликовано: 15.04.2021 16:37:31
I did it!
Yes, it performs very fast just as "usual" builds.
I have checked it only 2-3 minutes yet so far so good.
Everything seems in order, well done.
