Modeller Region - Introduction of Modeller Region with how to use step-by-step instruction - Сообщения
Thanks Martin and Jean. The slider is pretty neat.
Hello, thanks for this magnificent plugin it is very useful but all its functions are not documented.
It would be great if someone could upload the documentation of all the features of the plugin because discovering them one by one is a bit cumbersome.
Thank you very much in advance
Hello, please someone knows how to rotate text in modeller region?
WroteHello, please someone knows how to rotate text in modeller region?
Hi. This is a workaround, based on https://en.smath.com/forum/yaf_postst20332_Drawing-Text.aspx
DrawingTextModeller.pdf (104,58 КиБ) скачан 912 раз(а).
DrawingTextModeller.sm (278,08 КиБ) скачан 1671 раз(а).
WroteWroteHello, please someone knows how to rotate text in modeller region?
Thanks Alvaro, your implementation is very interesting, but I would like to know how to rotate the normal text (green label) without distorting it.
WroteUse 270 as 4th argument to rotate 90° counter-clockwise
Text Rotation in modeller region with 270 as fourth argument is not working under Linux.
I had encountered this several months ago, maybe years. Forgot to report it.
WroteText Rotatior in modeller region with 270 as fourth argument is not working under Linux.
I'll look into it, thank you.
![2021-08-10 12_56_37-SMath Studio - [common_functionality.sm_].png](/ru-RU/files/Download/XDXsod/2021-08-10-12_56_37-SMath-Studio---[common_functionality.sm_].png)
