Gamma Functions
Gamma Functions - rapid speed with precision - Сообщения
#21 Опубликовано: 11.06.2021 14:49:26
Sanity checked vs Mathcad 11.
Cuts the mustard a bit finer than first version.
Γ(1,0)="Uncertainty" unsolved.
#22 Опубликовано: 11.06.2021 14:56:09
There is no uncertainty in gamma_r6.
Everything look correct with those numbers.
Γ(1)=1
γ(1,0)=0
Γ(1,0)=1
#23 Опубликовано: 11.06.2021 16:33:56
1. Example 3 ... added
2. Uncertainty solved for version not having 0 defined.
Gamma [overlord sr.6].sm (39,32 КиБ) скачан 1125 раз(а).
#24 Опубликовано: 12.06.2021 02:20:08
3. don't want to disrespect, Alvaro's is a single line awesome code.
4. mine has same algorithm with more features, with faster calculation.
Hi overlord, of course you don't. My codes are mostly pedagogical, not for optimized for speed nor accuracy or something else. It's good to have codes with that.
#25 Опубликовано: 12.06.2021 10:15:48
Thanks, inspired by your code using sum(), and eliminating some useless variable definitions;
I have managed to speed up 30% percent under linux. And should be more precise now.
Only the 15th decimal digit may differs, and this is only sometimes.
gamma_r7.sm (28,8 КиБ) скачан 1437 раз(а).
#26 Опубликовано: 12.06.2021 14:58:22
Apparently solve() can't read product() too.
Had to change algorithm style for incomplete function.
Hopefully this is the last version.
Well, I have my doubts... (swh)
PS: solvers may not found an answer just because variable names, Razonar's idea implemented.
gamma_r8.sm (29,61 КиБ) скачан 1425 раз(а).
gamma_r8.sm (31,51 КиБ) скачан 1459 раз(а). <---gamma_r8-2 (function variable revision)
#27 Опубликовано: 12.06.2021 20:03:48
The algorithm is valid for Re(z) > 0. See this notes please.
gamma.sm (27,93 КиБ) скачан 1877 раз(а).
#28 Опубликовано: 12.06.2021 20:20:04
Can't be more right !
1. Smath Lanczos Davide code is 1/1 Keisan, Mathcad 11.
2. It supports imaginary argument.
3. It supports RootSecant.
4. Confirmed, your last Lanczos does not support RootSecant.
I haven't checked Alvaro suggestion.
#29 Опубликовано: 12.06.2021 20:23:36
... just a remark:
Mathsoft suggested use exp(,) instead of e^.
exp(,) more accurate/faster at kernel level.
#30 Опубликовано: 13.06.2021 01:26:31
Imaginary numbers supplicated.
Root Secant better than HT Davis. (last digit)
Graphing works for all functions.
Usually all solve methods works.
gamma_r9.sm (36,93 КиБ) скачан 1834 раз(а).
#31 Опубликовано: 13.06.2021 11:18:41
Your latest sr.9 is mostly red in SS 6179, takes Eternity.
Who cares ^308 ?
On the other hand, could be damned slow in practical applications.
Because not being built-in in native Smath ... proof:
Lanczos plots Hypergeometric but takes 1 min versus resident Gamma(x).
Why not use Lanczos as given by Davide ?
#32 Опубликовано: 13.06.2021 15:26:22
Who cares ^308 ?
- Who cares SMath 6179?
- My algorithm is faster than your examples.
- My Γ(x) prints hypergeom in less than a second, don't need integrated Gamma().
- Because my function has more features, and faster.
Your PC is slow, your SMath_6179 is slow and broken, your examples are slow.
Gamma [H.T. Davis, Lanczos_overlord].sm (62,36 КиБ) скачан 1295 раз(а).
Gamma [H.T. Davis, Lanczos_overlord].pdf (155,73 КиБ) скачан 732 раз(а).
