Symbolic evaluation
Symbolic evaluation - Unexpected behavior - Сообщения
#1 Опубликовано: 12.01.2026 11:29:15
Fabbro
Fabbro
0 сообщений из 21 понравились пользователям.
Good morning to all,
I'm checking some symbolic hand calculation and getting used (again, after a stop) with symbolic calculations in SMath.
And I've encountered some "strange" behaviors : it seems that, depending on how the same function (to be evalueted symbolically),
is written, the result is the one expected or not....
I'd not say, in a first instance, it is a bug: maybe I'm violating something implemented
in SMath...please, have a look to the attached file.
Any suggestion is more than welcome!
Thanks
TMMT formulas verification.sm (45,89 КиБ) скачан 234 раз(а)." title="TMMT formulas verification.sm (45,89 КиБ) скачан 234 раз(а).">TMMT formulas verification.sm (45,89 КиБ) скачан 234 раз(а).
#2 Опубликовано: 13.01.2026 02:22:32
587 сообщений из 1 360 понравились пользователям.
Choose a better alternative for symbolic calculations.
Maxima or Maple plugins usually (always) win over built-in engine.
Expand function generally does what you seek.
Click to enlarge
Отредактировано 13.01.2026 02:23:31
Alvaro 13.01.2026 18:02:24, Fabbro 20.01.2026 11:51:30
#3 Опубликовано: 20.01.2026 12:55:30
Fabbro
Fabbro
Thanks OVERLORD!
"Maple plugin" works fine and really quickly!
Some more details:
--> I directly typed "expand"...so, I wonder if there is a list of commands (such as "expand") somewhere...
In case yes, here, specifically, I'd be interested to simplify / factor out (in Mathcad this function si called "simplify") the symbolic result
--> Enlarging the point of view.... As far as I can understand the Maple plugin use the Maple calculation engine
(what is free at least)...If so do you think it can be used elsewhere? I'd be particularely interested in functions of 1 variable
generated from matrices (4x4 and higher) multiplication in chaine...If Maple engine could speed up calculations it would be great..
Clearly I can create a new post with attached the specific spreadsheet....
About "Maxima plugin": I cannot find nor a plugin Maxima nor a function....some indications more?
Many thanks again & best regards
#4 Опубликовано: 21.01.2026 16:02:24
1 334 сообщений из 2 249 понравились пользователям.
See https://nbn-resolving.org/urn:nbn:de:kobv:522-opus4-29497 for instructions and reference for the Maxima plugin.
ioan92 27.01.2026 13:51:16, Fabbro 21.01.2026 21:37:20
#5 Опубликовано: 22.01.2026 18:44:48
Fabbro
Fabbro
Dear MARTIN,
thank you very much for your reply!
Indeed, I downloaded both the plugin and Maxima.
And it works fine for the specific issue I highlighted.
I had a look also to your document on Maxima.
Going further (as for Overlord and Maple plugin) I'd like to know if (and how...) Maxima could
improve the time of calculation of a function derived from matrices multiplications.
The function is the characteristic equation of a transfer matrix for a non-uniform beam...better, the transfer
matrix of a beam made by multiple, uniform beams, different each other (multi-stepped beam)....
After a lot of numerical test I'm convinced that the best way to find roots of the characteristic
equation is:
--> plot the characteristic equation in the interval for interest
--> inspect for the minimum of the log10( absolute (characteristic))
--> find the mimimum
But for that, you have to built/calculate a huge amount of points of the characteristic equation.
The final goal is the calculation of lowest roots of the characteristic equation for a multistepped beam made
by 50 single beams, in a reasonable time (let's say a couple of hours).
In the attached file you have an example....the characteristic equations are highlighted in
pale blue.
3RodsStepped_vs_measures V10 _for Prof Kraska.sm (281,96 КиБ) скачан 194 раз(а).Whatever the suggestion you've , is more than welcome!
Many thanks and best regards
#6 Опубликовано: 23.01.2026 09:46:18
An include file is missing, so I can't run your worksheet. Also make sure that all your math regions are set to numerical optimization.
Fabbro 23.01.2026 10:34:38
#7 Опубликовано: 23.01.2026 14:08:10
Fabbro
Fabbro
Dear MARTIN,
really sorry, I apologise for that.
Here attached a new version of the file and the file called by include.
Following your advice, I checked in all the reqions the optimisation options: they were on "numeric" or "symbolic"
without apparent logic....
I assumed that the default optimisation option was "numeric". To be set on "symboilic" or "none" by manual choice:
I'll pay more attention to this detail!
By the way, I left the optimisation option on "symbolic" ONLY for the expression highlighetd in cyan.
Set this way the sheet takes 1402 secs to run.
As said, any suggestion is more than welcome!
Fabio
TMMT algo_under_crit.sm (98,11 КиБ) скачан 175 раз(а).
3RodsStepped_vs_measures V10 _for Prof Kraska V1.sm (282,78 КиБ) скачан 190 раз(а).
#8 Опубликовано: 17.03.2026 06:57:57
Norrah_Casper
Norrah_Casper
Symbolic calculations in SMath can definitely feel like a bit of an art form sometimes. I noticed the same 'unexpected behavior' in similar builds. Are you using the native engine or a specific plugin for this? Usually, re-ordering the definitions helps, but it’s strange that the same function gives different results.
