the issue with imaginary numbers in equations answers
the issue with imaginary numbers in equations answers - Messages
#1 Posted: 2/26/2020 11:15:45 AM
Вуаутвук
Вуаутвук
0 likes in 11 posts.
Some of my answers include "і" signs, what should I do to get a regular answer?
At first, I thought it was a problem in the cosine equations but later saw the same problem in other formulas.
TROPtaKhV_Lb2.sm (356.86 KiB) downloaded 1047 time(s).
#2 Posted: 2/26/2020 11:31:50 AM
127 likes in 342 posts.
"i" indicates that this is a complex number with an imaginary part.
It is completely normal for the cases you have exposed since the square root of a negative number does not make sense in the real field (it is a complex number); in the same way, the arc-cosine makes sense in the real field only for numbers less than or equal to 1
Вуаутвук 2/27/2020 7:00:00 AM
#3 Posted: 2/26/2020 11:40:55 AM
literal 'l' is too confusing, use λ [Greek]
imaginary 'i' and ordinary 'i' are not compatible
especially in for loop... please check.
TROPtaKhV_Lb2 Test back.sm (356.86 KiB) downloaded 1054 time(s).
