1 Pages (5 items)
Difference in plotting - One case requires x as independent vatiable the other accepts t. - Messages
#1 Posted: 9/20/2012 7:18:21 PM
#2 Posted: 9/20/2012 8:23:37 PM
WroteHello,
Does anybody knows why this difference in the independent variable?
Thank you,
Basile
Hi Basile,
I'm not sure but I think it's something related to "local" and "global" variables... using the line() [MATH]t[/MATH] becomes a local variable for [MATH]i(t)[/MATH], and the "global" [MATH]t:x[/MATH] doesn't affect the function, vice versa without the line() [MATH]t[/MATH] is a global variable for q(t) so plotting the graph you implicitly write "plot q(x)".
regards,
w3b5urf3r
#3 Posted: 9/21/2012 8:54:32 AM
Hi Basile.
By default x is a global variable in SMath. When you define i(t), t is a local variable.
So, while you try plotting i(t) you get an error because t is not defined. When you define t=x, you obtain plots for i(t) and q(t)
Oscar
Oscar
#4 Posted: 9/21/2012 9:40:06 AM
I can plot q(t) but not i(t) although I defined t:=x.
Can the definition of the functions have anything to do with that, one uses the if statement the other is as usually.
Basile
Basile
#5 Posted: 9/21/2012 11:49:29 AM
WroteHello,
Basile
You're right, the issue is in the if statement (see the attachments)
to bypass the issue use this workaround:
[MATH]i(t)
regards,
w3b5urf3r
test.sm (8.3 KiB) downloaded 1272 time(s).
1 Pages (5 items)
