simple integrals give give difficult results
simple integrals give give difficult results - Messages
#1 Posted: 8/12/2019 4:52:05 PM
hakelm
hakelm
0 likes in 4 posts.
Integrating the simple functions 1/x, 1/x², 1/x³ upwards from 1 give correct results for low values of the upper limit but with the upper limit in the order of 200 or higher the results are not what I would expect. Please see the attached worksheet.
Is there a problem with the integral function or is there something I haven't grasped?
H
integral.sm (5.38 KiB) downloaded 948 time(s).
#2 Posted: 8/13/2019 1:33:32 AM
1,123 likes in 1,795 posts.
Hi. It's because the integral it's a numerical procedure, and maybe not a very robust one. So, like any numerical method, if it don't work, just use another.
integral.sm (13.76 KiB) downloaded 993 time(s).
#3 Posted: 8/13/2019 5:04:21 AM
127 likes in 342 posts.
Hakelm,
I opened your file and the results were correct. Therefore I believe that the parameter for the accuracy of the integrals in your SMath installation is not correctly set.
Try to change Tools->Options->Calculation->Integral Accuracy
For example, write 1000
However, Alvaro's considerations must be kept in mind
#4 Posted: 8/13/2019 6:50:17 AM
hakelm
hakelm
0 likes in 4 posts.
Many thanks for two very good answers!
Now I know that Smath doesn't know even the simplest of integrals but that approximation accuracy can be improved upon.
Even if I understand my system doesn't (SMathStudioDesktop.0_99_7109.Mono on Ubuntu 16.04).
It can't find the function Rkadapt.
I guess that the Runge-Kutta functions are to be found i some plugin. Where can I find that?
H
#5 Posted: 8/13/2019 8:44:46 AM
1,554 likes in 1,864 posts.
ODE Solvers.
#6 Posted: 8/13/2019 10:35:06 AM
The Simpson integrator ranges from exact to freak.
In your examples, increase the integral accuracy from
menu, options, calculations, integral accuracy [max 10000]
Wise to sanity Wolfram Alpha cost is 0.00 $
integral.sm (46.96 KiB) downloaded 971 time(s).
#7 Posted: 8/14/2019 10:19:49 AM
hakelm
hakelm
0 likes in 4 posts.
May I assume that the SMath-integral is made using Simpson's rule and that the integral accuracy [max 10000] is the number of steps taken by Simpson?
H
#8 Posted: 8/14/2019 11:14:29 AM
Quite right: The Smath integrator is Simpson.
Ranged accuracy [50 ... 10000]. Trivial cases are exact.
Two more exact cases are know 1/x [ln(x), b_spline].
On long range of the variate 'x' the Simpson/Romberg kernel
gives a much better result than simple Simpson.
Carlos adaptive algorithm is fool proof all cases.
You want these two proposed ... reply YES/NO.
#9 Posted: 8/14/2019 1:53:22 PM
hakelm
hakelm
0 likes in 4 posts.
Yes please
H
#10 Posted: 8/14/2019 7:07:51 PM
As you can see, Romberg has the virtue of reducing the range of integration
in the [0 ... 1 ] domain. In two versions directly associated with the
Smath native Simpson integrator or Simpson algo style, thus integration
accuracy 'n' @ the user command line.
These two documents are like minimalist tool box.
Integrate Compendium_1 Romberg_FD_Adaptive [Carlos].sm (142.88 KiB) downloaded 878 time(s).
Integrate Compendium_21 Simpson-Romberg Merit.sm (138.06 KiB) downloaded 989 time(s).
