Vlookup Delay
Vlookup Delay - Messages
#1 Posted: 2/18/2018 12:15:39 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
An automatic electronic device had been installed on the bank of a stream to record and transmit Water Levels (at half hour intervals) to a control center, where the readings were converted to discharge values, for further analysis, using an already established Rating Table. These data are given in an Excel file.
The attached SS file takes nearly 2 minutes to convert 1 month data values (48x31=1488).
I have tried this with several previous SS versions also.
Can this be improved, as we have to deal with data recorded for over 5 years?
My system: Win 10 Pro, 64 bit, Core i5, 6 GB Ram Laptop.
Any help will be much appreciated please
WL To Q.sm (18.46 KiB) downloaded 1152 time(s).
1.July WL&RT.xlsx (29.52 KiB) downloaded 1046 time(s).
#2 Posted: 2/18/2018 3:42:00 PM
2,343 likes in 4,043 posts.
Hello.
First impression is that you should try using findrows(...) function (built in into the program) in this case.
vlookup(value,table,column):line(findrows(table,value,column-1),1,1)
Before change:
2 min. 14 sec.
After change:
2.4 sec.
But I see different results of using vlookup implemented in your worksheet (returns 1488 rows vector) and findrows (returns 2976 rows vector). Unfortunately I have no chance to deep into the logic, but this may be a good starting point.
#3 Posted: 2/18/2018 4:23:08 PM
Did find 5 minutes more to look into it and finally I did it:
WL To Q_mod1.sm (16.4 KiB) downloaded 1157 time(s).
Takes 1.7 sec. on my environment.
#4 Posted: 2/18/2018 5:19:13 PM
Maybe the other way around => vlookup needs be doctored.
Mine works fine 0.06 s scanning 9 rows for one value
FindRows => 2.4 s scanning 31 rows ... for ONE value, is it ?
Utilities Matrix lookup.sm (11.18 KiB) downloaded 1180 time(s).
#5 Posted: 2/18/2018 11:16:33 PM
NDTM Amarasekera
NDTM Amarasekera
