Beta: SMath Studio 0.99.6982 (12 February 2019)
Beta: SMath Studio 0.99.6982 (12 February 2019) - Messages
#1 Posted: 2/12/2019 12:50:19 PM
2,343 likes in 4,043 posts.
SMath Studio
Changes introduced in current build 0.99.6982
Improvements
  • Added possibility to display multiple pages side by side if there is enough horizontal space on the screen (in order to control this feature Multiple Pages menu item added to the View menu);
  • Added ability to specify behavior on calculation error occurs: Continue (default), Pause or Interrupt;
  • Added ability to change math variable by pasting text from Clipboard.
Corrections
  • Incorrect cursor position sometimes happened after paste (depending on localization settings) fixed;
  • SS-3572: Possibility to interrupt calculation manually improved.
Miscellaneous
  • Several minor graphical glitches fixed;
  • Error message location corrected on Worksheet scrolling;
  • Overall application stability increased;
  • Refactoring.
Download
SMathStudioDesktop.0_99_6982.Mono.tar.gz (1.36 MiB) downloaded 2041 time(s).
SMathStudioDesktop.0_99_6982.Setup.msi (2.23 MiB) downloaded 4221 time(s).
BTW: Interrupt on error is very handy - allows to break further Worksheet calculation if anything goes wrong. May really simplify work with large documents.
Use Ctrl+Mouse Wheel to play with Multiple Pages feature.
8 users liked this post
Radovan Omorjan 2/12/2019 12:57:00 PM, Arie 2/12/2019 12:58:00 PM, NDTM Amarasekera 2/12/2019 1:07:00 PM, Вячеслав Мезенцев 2/12/2019 1:39:00 PM, frapuano 2/12/2019 1:52:00 PM, Serg 2/12/2019 3:23:00 PM, sergio 2/12/2019 3:24:00 PM, Davide Carpi 2/13/2019 4:15:00 AM
#2 Posted: 2/12/2019 3:39:00 PM
genf
genf
6 likes in 72 posts.
В последних версиях заметил такую особенность: когда подгружено много плагинов программа задумывается при вызове доступных функций (вроде как начинает просматривать что есть и поэтому всё зависает на несколько секунд), да и при дальнейшей работе в окне все довольно не быстро.
В старых версиях тормозов замечено не было.
Небольшое кино: нажать тут
Со стандартными функциями работает все быстро.
Можно как то оптимизировать?
#3 Posted: 2/12/2019 4:59:47 PM
1,555 likes in 1,867 posts.
Для начала убрать лишние плагины. Очень много функций в DISLIN, которым пока не имеет смысла пользоваться. Также можно убрать Matlab и Octave плагины, если используется 64-битная версия программы. EFI плагин нужен только для поддержки старых Mathcad'овских библиотек. Он тоже не нужен скорее всего. NumPlugin - это просто пример плагина, так же как и VBNetPlugin. Они не нужны.
3 users liked this post
Andrey Ivashov 2/12/2019 6:04:00 PM, Serg 2/13/2019 2:12:00 PM, sergio 2/12/2019 5:18:00 PM
#4 Posted: 2/12/2019 6:07:37 PM
Спасибо, что сообщили! Посмотрю что можно сделать.
#5 Posted: 2/13/2019 9:37:12 AM
genf
genf
Ок. Спасибо.
На самом деле это был эксперимент. Само собой в реальной работе 90% не использую.
#6 Posted: 2/14/2019 4:58:10 PM
Поправил. Теперь диалог работает моментально вне зависимости от того, сколько плагинов установлено.
Serg 2/15/2019 3:14:00 AM
