Varying results for trig function
Varying results for trig function - Messages
#1 Posted: 2/27/2012 12:09:48 PM
scottg
scottg
0 likes in 2 posts.
I found a minor problem with trigonometric functions. The following problem occurs only for a value of 30 degrees, as you can see the value of sin evaluates differently depending on the construction of the math. And only when I am modifying the value of phi in expression shown.
It would not be a problem if a value of phi = 30 was not common in geotechnical engineering.
[MATH]φ:30deg[/MATH]
[MATH=eng]γ:1.3[/MATH]
[MATH=eng]δ:atan(tan(φ)/γ)[/MATH]
[MATH=eng]δ=23.9468@'deg[/MATH]
[MATH=eng]β:sin(δ)[/MATH]
[MATH=eng]β=1.2177[/MATH]
[MATH=eng]sin(δ)=0.4059[/MATH]
Any thoughts?
#2 Posted: 2/27/2012 3:13:33 PM
The solution is to apply Optimization|Numeric or None on the region:
[MATH=eng]δ←atan(tan(φ)/γ)[/MATH]
This is a common advice to do first when you need just the numerical values.
BTW, the degrees does not work properly in v0.92
#3 Posted: 2/27/2012 3:18:41 PM
It doesn't wort in one case only - when you try to evaluate it numerically in a single line like:
P.S.: Will try to release new SMath Studio version as soon as possible.
Radovan Omorjan 2/27/2012 3:25:00 PM
#4 Posted: 2/28/2012 5:18:42 AM
scottg
scottg
0 likes in 2 posts.
Thanks for the help
#5 Posted: 3/5/2012 5:47:22 AM
127 likes in 342 posts.
Also in v.093 remains the problem reported by Scottg. The solution indicated by Radovan, it works properly.
Sergio
Davide Carpi 3/5/2012 5:53:00 AM
#6 Posted: 5/30/2012 4:04:55 PM
Fixed in SMath Studio 0.94.
Radovan Omorjan 5/30/2012 4:06:00 PM, Davide Carpi 5/30/2012 4:11:00 PM
