Beta: SMath Studio 0.99.6955 (16 January 2019) - Messages
SMath Studio
Changes introduced in current build 0.99.6955
Improvements
- Added support for high DPI environment (application is not blurry anymore).
Miscellaneous
- Read-only Picture Region loading from file fixed;
- Page Up, Page Down, Home and End keyboard commands restored;
- Horizontal Worksheet scrolling improved;
- Possibility to use mouse wheel inside Regions restored.
Download
SMathStudioDesktop.0_99_6955.Mono.tar.gz (1.35 MiB) downloaded 1992 time(s).
SMathStudioDesktop.0_99_6955.Setup.msi (2.23 MiB) downloaded 4232 time(s).
Please note:
5346 had the the indefinite integral in the f(x)menu, thus available for maple.
It was removed 6179, but it could be called within maple maple(int,)
This last facility does not work anymore.
About that, Davide replied 19 days ago:
"I cannot reproduce the autocomplete of int in any SS version, neither changing the date on the machine, and I'm not aware that there ever were such behavior...
however, I don't think it is a desirable feature; how would you access or create any int~ variable/function if the program triggers the autocomplete while you are typing? (and imagine this extended to any function...)"
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
Gamma [15 D Alvaro].sm (9.33 KiB) downloaded 1331 time(s).
WroteAnother question ... what do you calculate ?
As it looks, not that many Smath latest version users are interested.
Thank you Jean. I will check.
WroteWhat about the indefinite integral ?
Davide answered you correctly in a separate topic.
WroteThank you Jean. I will check.
Thanks in advance Andrey for eventually doctoring.
I have tested exhaustively Alvaro Γ(x) 15 decimals vs Mathcad
Further, Definite Integration does not need be vectorized.
Gamma [15 D Alvaro].sm (10.94 KiB) downloaded 1362 time(s).
