Crash on saving
Crash on saving - Improper saving when opening files from forum - Messages
#1 Posted: 2/20/2018 5:33:48 AM
MBe
MBe
2 likes in 21 posts.
Hello to Everybody,
I just noted a strange behaviour of Smath, I am using release 99.6622 but I believe it is the same in other versions.
If you open a file on the fly (without downloading) from an external source (i.e.: Smath Forum) and then you make any change to it, when you close the file you are prompted with a request to save the file.
If you (improperly) answer "Yes", Smath crashes.
I think Smath is right in the sense that you shouldn't save to a read-only location, but for the sake of completeness, you might want to protect against improper use from inexperienced users...
Thanks for the attention
Marco
#2 Posted: 2/20/2018 6:30:46 AM
1,443 likes in 2,935 posts.
Grazie Marco
Bug confirmed (unhandled System.UnauthorizedAccessException).
Guess the right way is:
1) check for permissions
2) If permissions are denied, prompt the "save as" dialog;
#3 Posted: 2/21/2018 3:51:39 AM
Hello, Davide.
I've made some improvements to saving logic. Please could you check the same scenario with latest sources?
Unfortunately I'm unable to reproduce this issue.
Thanks in advance!
#4 Posted: 2/21/2018 4:50:57 AM
Hello Andrey,
Not fixed with your improvements. To reproduce simply mark a file as readonly from the system file properties before opening it with SS.
In my sandbox folder there is a possible solution
Andrey Ivashov 2/21/2018 4:29:00 PM
#5 Posted: 2/21/2018 12:01:26 PM
Hello to Everybody,
Marco
Hello Marco,
Superb description, the missing link is that if you save from open on the fly,
good thing Smath crashes ... What ! Yes What, how Smath knows where to save ?
Back to originator ... no way. Why not Save as ...
Have you tried copy/paste on new sheet => Save as in some addressed location ?
#6 Posted: 2/21/2018 3:15:13 PM
This is not a big deal, the file downloaded for reading is stored in a temporary path and flushed when you close the browser, Smath knows the path and since is a temp folder can write in it . But the downloaded file it is set as read-only and can't be overwritten (this is not handled, hence the crash); best way from my point of view is to simply prompt the "save as" dialog that is opened on the default location; this it works on any read-only file, and you can still get an error messsage from the system if you try to overwrite the file from within the dialog.
#7 Posted: 2/21/2018 3:31:34 PM
Thank you very much Davide!
I've taken your fix as a basis and extended it to support all possible places where saving to file may be called (i.e. desktop UI, silent mode, etc.). So, this is done now.
Davide Carpi 2/21/2018 3:33:00 PM
#8 Posted: 2/21/2018 4:29:06 PM
FYI: Fix is a part of just released nightly build: https://en.smath.info/forum/yaf_postst12549_SMath-Studio-0-99-6626--21-February-2018.aspx
Davide Carpi 2/22/2018 8:39:00 PM
