Cannot run in Ubuntu 22.04
Cannot run in Ubuntu 22.04 - Messages
#1 Posted: 9/28/2023 3:57:49 PM
vroberts
vroberts
0 likes in 7 posts.
I cannot run the SmathStudio appimage in Ubuntu 22.04. Other appimage programs do run on the system, so I seem to have the proper resources. There is no error message. Just nothing.
#2 Posted: 9/28/2023 6:51:04 PM
582 likes in 1,350 posts.
This is mono bug of debian based distros. You can find detailed explanation about it at link below.
https://en.smath.com/forum/yaf_postsm75553_SMath-in-Linux.aspx#post75553
#3 Posted: 9/29/2023 12:57:15 PM
vroberts
vroberts
0 likes in 7 posts.
If SM does not run on Debian based distros, I wonder why Ubuntu is listed on the Download page as the example of a Linux distro.
#4 Posted: 7/20/2024 5:05:00 AM
David Cigna
David Cigna
0 likes in 2 posts.
I know this is a 10 month old thread, but this is such a common problem that I think it's worth responding.
overlord did not say that smath does not run on Debian based distros. I think that what he implied is that if it won't run, then you need to fix your mono installation.
One thing that finally worked for me was to install not just the mono runtime, but also the developer package:
sudo apt update
sudo apt upgrade
sudo apt install mono-runtime mono-devel
You can refer to this thread for more ideas:
Ask Ubuntu
#5 Posted: 7/20/2024 5:23:41 AM
In fact, you even don't need to fix or install anything. This is a common mono bug and it can be fixed with editing your smathstudio mono execution file.
With respect to pdalet, here is his post.
Good New for ubuntu users
SMath Studio runs on ubuntu 22.04 without sudo.
Modify smathstudio_desktop_mono
#!/bin/sh
export MONO_WINFORMS_XIM_STYLE=disabled
exec mono "./SMathStudio_Desktop.exe" "$@"
Ph.DALET
Lyp Champollion
Figeac-FRANCE
#6 Posted: 8/3/2024 12:25:22 AM
giddyApples8
giddyApples8
0 likes in 15 posts.
#!/bin/sh
Ph.DALET
Lyp Champollion
Figeac-FRANCE
Can you please explain how (which app to use) to modify the mono file?
#7 Posted: 8/3/2024 3:55:00 AM
This file (smathstudio_desktop_mono) is just a shell script file.
Edit it with your favorite text editor.
vim, leafpad, kate, nano, scite, notepadqq, etc etc
#8 Posted: 8/6/2024 1:59:10 AM
David Cigna
David Cigna
0 likes in 2 posts.
Just to add a tiny bit for those that are not linux gurus. Overlord's suggestion works well if you place the shell script in the same folder as SMathStudio_Desktop.exe, cd into the folder with a command line, then execute smathstudio_dektop_mono. For those that prefer using a launcher to the keyboard, you need to modify the script a little more.
#!/bin/sh
cd /home//Applications/SMath_Studio
I made a folder called SMath_Studio within the Applications folder (which may or may not already exist in your home directory) and copied the entire SMath file structure there. Obviously, replace with your user name. Now create an entry in your launcher that executes the shell script. The reason that all of this is necessary is because SMathStudio_Desktop.exe needs to start in the same folder as all of the associated SMath files. Simply specifying the complete path in the "exec mono" line will not be enough.
#9 Posted: 1/31/2026 12:04:04 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 179 posts.
//////////////// DISCLAIMER \\\\\\\\\\\\\\\
I am new to Linix (Ubuntu - Zorin OS)
Greetings,
I am currently binge watching a plethora of videos covering Ubuntu, LInux, Wine, Gear Lever: installs, debugging, and the such. Here is my current understanding:
  1. Mono is outdated, a project that has hence been folded into WineHQ
  2. The Mono distribution WILL work with Mono, or with WineHQ, either one having different degrees of success (e.g., Mono displayed math regions, but not some button text, while Wine showed button text, but not some math region text) ¯\_(ツ)_/¯
  3. The *.appimage file for Ubuntu doesn't seem to 'work', even after authorizing it to run, neither through 「fuse2」, nor 「Gear Lever」: No errors, no messages.
  4. I have developed some plugins, so I'm aware that SMath is an Windows Forms application/.net/Microsoft
Is it a valid understanding that SMath does not have a "Linux deployment," but rather it is a Windows Application that *can* run on Linux; more or less supported through the Mono project.
Therefore, here are my questions:
  • Is there an installation guide for Linux Deployments?
  • Does the Ubuntu deployment appImage file corrupt? if not, how is it supposed to be used?
  • If SMath only works if it is mounted to "Mono" or "WineHQ": is there a way to double click a *.sm file and have the SMath open? or must we enter that command through the terminal
I have a 'working' solution, but I'm looking for the cleanest/mainstream/recommended/seamless method as to how best install/utilize SMath Studio.
May this be of Good Help;
#10 Posted: 2/2/2026 6:57:04 PM
Usually Debian based distros have issues with Mono compiled programs.
Check if SMath runs with sudo from terminal. Sometimes a missing library indicated at terminal.
If you write version of your Zorin installation, I can check it from live iso.
#11 Posted: 2/2/2026 10:05:07 PM
Greetings,
Thank you for that reply. From experiments, SMath doesn't like WineHQ much on ZorinOS (Ubuntu-based); issues with displaying/interacting with Unicode characters. I was going to try Bottles and other alternatives (like VM) to see if there is a better environment for SMath. Looks like the same issue as noted on this other thread:
Hello, I use Smath studio for education purpose. I previously had it on debian strech were it works very well but now I switch to ubuntu 18.04 and I install it with the deb package.
The issue is I cannot see all the symbols in the toolbar. It's the symbol wich is Black over white in omorr screenshot.
Sombody have an idea? a dependencie missing?
ref: https://smath.com/en-US/forum/topic/4za86Z/SMath-Studio-for-Ubuntu#msg122545
(I'm working off of Zorin OS 18 Educational; v1.42.0)
Edited 2/2/2026 10:07:30 PM
