1 Pages (18 items)
UPDATED: SMath Studio 0.98.5952 (18 April 2016) - Messages
#1 Posted: 4/16/2016 7:23:54 AM
SMath Studio 0.98.5952 available
Latest changes (against SMath Studio 0.98.5932)
- Look and behavior of changing visible elements for output matrix significantly improved;
- Math Region performance improved in case of large expressions to be shown;
- SS-6: Region's error status cleared on description change for custom regions;
- SS-2312: Critical errors on pressing buttons from palette when cursor is in text entry inside the math equation;
- SS-2314: Function try(..) implemented;
- SS-2317: Font-size of the text in evaluable regions on file open fixed;
- Print page by page number issue fixed (happened after Print Preview shown);
- Multi-threading related issue fixed (rarely happened on file open);
- Refactoring.
Download
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_98_5952.Setup.msi (Date: 18.04.2016. File size: 2.01MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_98_5952.Mono.tar.gz (Date: 18.04.2016. File size: 1.15MB) - last version of Mono distributive required! - Cloud version (all modern browsers supported):
SMath Studio in the Cloud (Date: 18.04.2016.)
7 users liked this post
Mike Kaganski 4/16/2016 7:49:00 AM, Василий Николаевич Храмушин 4/16/2016 9:31:00 AM, frapuano 4/16/2016 9:38:00 AM, Radovan Omorjan 4/16/2016 10:51:00 AM, Davide Carpi 4/16/2016 12:26:00 PM, overlord 4/16/2016 8:34:00 AM, sergio 4/16/2016 7:51:00 AM
#2 Posted: 4/16/2016 8:46:30 AM
I can create new descriptions, but cannot edit existing - it throws an exception.
С уважением,
Михаил Каганский
#3 Posted: 4/16/2016 8:48:45 AM
Thank you. Will check it today.
I did good code review again, so some simple issues are possible.
#4 Posted: 4/16/2016 8:59:52 AM
No problem - that's what nightlies are for.
Other problem: error description (and lastError) seem to be in OS language, regardless of SMath UI language.
E.g., in my Russian Win10, SMath UI is set to English, but for an erroneous block, I get error text "В экземпляре объекта не задана ссылка на объект.".
С уважением,
Михаил Каганский
#5 Posted: 4/16/2016 9:21:05 AM
WroteI get error text "В экземпляре объекта не задана ссылка на объект.".
This is exception which is not handled correctly. That is why error is meaningless and not localized.
Please explin how can I reproduce it.
#6 Posted: 4/16/2016 9:22:44 AM
WroteWroteI get error text "В экземпляре объекта не задана ссылка на объект.".
Page8.sm (1.8 KiB) downloaded 1989 time(s).
С уважением,
Михаил Каганский
#7 Posted: 4/16/2016 12:31:28 PM
WrotePage8.sm (1.8 KiB) downloaded 1989 time(s).
If I place the cursor in the rightmost placeholder and I press 2 times the "delete" key, I get an IndexOutOfRange exception;
System.IndexOutOfRangeException: Index was out of bounds of array.
in SMath.Control.MathRegion.InsertManager(String value)
in SMath.Control.MathRegion.OnCommandSend(String value)
in SMath.Control.Worksheet.InsertManager(String value)
in SMath.Control.Worksheet.Insert(String value)
in SMath.Control.WorksheetControl.OnKeyPress(KeyPressEventArgs e)
in SMath.Control.Worksheet.OnKeyPress(KeyPressEventArgs e)
in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
in System.Windows.Forms.Control.WmKeyChar(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Andrey Ivashov 4/17/2016 5:42:00 PM
#8 Posted: 4/16/2016 4:31:16 PM
Smath Studio 0.98.5950 creates "MathRegion.finish" error for several worksheets of mine and files couldn't be opened. Same files have no error at version 0.98.5932 and perfectly opened. I have uninstalled 5950 and installed 5932 with same plugins and there were no problems at all.
As far as I witnessed I can open ".sm" files partially by disabling the plugins. The problems for my files are CheckboxList, ComboboxList, RadiobuttonList, WriterRegion plugins.
#9 Posted: 4/16/2016 9:21:33 PM
WroteThe problems for my files are CheckboxList, ComboboxList, RadiobuttonList, WriterRegion plugins.
I've updated these 4 regions for this SS version (many thanks to Andrey for the help via skype); let me know if you notice other issues.
P.S. WriterRegion is relased as Beta, it contains also several minor fixes not related with this SS update and a new option to choose when to popup the toolbar (Options > Environment). If all it works fine I'll relase these things also for previous versions of SS.
#10 Posted: 4/17/2016 12:20:20 AM
thank you for quick return, now it seems all plugins work as they are supposed to be.
Davide Carpi 4/17/2016 6:54:00 PM
#11 Posted: 4/17/2016 12:32:34 PM
I see that in 0.98.5951 the problems with descriptions and error string for my file had been addressed - thank you!
Here is another file with the same error string - just assignment added.
for-error.sm (1.8 KiB) downloaded 1625 time(s).
С уважением,
Михаил Каганский
#12 Posted: 4/17/2016 1:21:00 PM
WroteHere is another file with the same error string - just assignment added.
Thank you! Will fix it.
#13 Posted: 4/17/2016 1:25:41 PM
Initial 0.98.5950 build of this topic replaced with 0.98.5951 which contains several minor issues. All plug-ins revised and new versions of many of them were released, so, please update your plug-ins using Extensions Manager.
Davide Carpi 4/17/2016 6:53:00 PM
#14 Posted: 4/17/2016 1:35:22 PM
units-vanish-on-matrix-resize.sm (2.72 KiB) downloaded 1651 time(s).
If you try to resize a matrix, units in it disappear.
Edit: incorrect statement: units are converted to non-units (symbol "'" disappears from them).
Also, copying matrices from/to a formula does the same. If you copy stand-alone matrix and paste it to a free space on sheet - it pasted OK. If you tried to paste to a placeholder in a formula, the following paste to a free space is with broken units (seems like clipboard is broken in that case).
С уважением,
Михаил Каганский
#15 Posted: 4/17/2016 4:47:01 PM
WroteIf you try to resize a matrix, units in it disappear.
Thank you very much. Both issues (unhandled error and units disappearing) are fixed!
UPDATE: SMath Studio in the Cloud already has these fixes.
3 users liked this post
Mike Kaganski 4/17/2016 5:37:00 PM, frapuano 4/17/2016 6:12:00 PM, Davide Carpi 4/17/2016 6:53:00 PM
#16 Posted: 4/17/2016 8:22:49 PM
"[" keyboard shortcut for el() behaves strange (doesn't add second placeholder?):
when you type a matrix name (e.g. "a" ) and then type "[", then instead of subscript, this functional form appears: "el(a) " (without separator and placeholder).
The same for nthroot() (Ctrl+\)
С уважением,
Михаил Каганский
#17 Posted: 4/18/2016 2:17:03 PM
Wrote"[" keyboard shortcut for el() behaves strange (doesn't add second placeholder?):
Errors are fixed and new beta available. Please check.
Thank you!
Davide Carpi 4/18/2016 2:35:00 PM, frapuano 4/18/2016 4:36:00 PM, Mike Kaganski 4/18/2016 5:26:00 PM
#18 Posted: 4/18/2016 5:46:04 PM
Sorry to be a nail in the ass,
but now nthroot's keyboard shortcut (Ctrl+\) doesn't work.
Trying to copy a unit from some formula and pasting it into a unit (rightmost) placeholder of a result of some formula doesn't succeed.
Newly added "try" element in tools panel hasn't tooltip.
abs() is absent in Insert-Function... (Ctrl+E) dialog.
С уважением,
Михаил Каганский
1 Pages (18 items)
