1 Pages (6 items)
XY GRAPHS VERSUS ZEDGRAPH - Lines are broken in Zedgraph - Messages
#1 Posted: 6/24/2023 8:01:55 PM
The attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH. Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
Both .sm and .pdf files are provided. The scale of the pdf must be enlarged to see the difference in the two graphs.
Thanks,
Reg
Thanks,
Reg
Reg CurryLoveland, CO
#2 Posted: 6/24/2023 9:51:15 PM
WroteThe attached files show the same calculation plotted in both the SMATH XY graph and a ZEDGRAPH. The lines are not as smooth in the ZEDGRAPH.Is this a quirk of ZEDGRAPH, or do I have some setting incorrect.
You plot the same data set on different plot ranges.
Make the two graphs consistent, for immediate comparison.
#3 Posted: 6/24/2023 11:02:48 PM
Try these.
NOTE: Arial 8pt in XY does not look the same in ZEDGRAPH.
#4 Posted: 6/24/2023 11:12:43 PM
Sorry for the huge screenshot.
Its due to line and symbol settings of traces.
Changing them will provide smoother line.
GRAPH COMPARISONS_smooth.sm (39.62 KiB) downloaded 1410 time(s).
#5 Posted: 6/24/2023 11:35:47 PM
Thanks much! That helps.
#6 Posted: 6/25/2023 7:40:06 AM
Your X_Y plot was spoiled.
If you click in the graph region and move the pointer,
it freaks the X & Y ranging ... your delivered 1rst attachment.
Zedgraph is more traditional of Bode plots.
GRAPH COMPARISONS_smooth.sm (39.62 KiB) downloaded 1337 time(s).
1 Pages (6 items)
