Units do not match
Units do not match - Not sure how to make unit match - Messages
#1 Posted: 10/15/2015 10:19:11 AM
Isai Delarca
Isai Delarca
0 likes in 1 posts.
I am new to using SMATH and could use assistance getting it to work for me. I am not sure what I am doing wrong. Attached is a screenshot of the variables and equations, unfortunately I can never get a result for Q1 and RV. I keep getting "units do not match", but don't know how to fix the problem. The results should be in inches and acre-feet.
Please let me know if you can help? Thanks in advance.
Runoff Calculations.sm (13.58 KiB) downloaded 1313 time(s).
#2 Posted: 10/15/2015 10:51:51 AM
Hi idelarca1,
hold the mouse pointer over Q.1yrpre, you can see that the sum is not possible, because S.pre is dimensionless while P is a length.
You have used "Ignore units", but this feature works fine only using direct assignments inside the function (look here)
Therefore you have to use the classic approach: modify Q.1yrpre to add a unit to S.pre or made P dimensionless.
