Some Snippets Do Not Show in Extensions Manager -> Snippet Window
Some Snippets Do Not Show in Extensions Manager -> Snippet Window - Some of the snippets in the snippets folder are not accessible inside smath page - Messages
#1 Posted: 1/8/2015 12:36:06 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
Why are some files saved in my snippets folder not available to select shen looking in the tools -> snippet manager ?
Attached is an example of such file.
Masonry - Pier.sm (73.58 KiB) downloaded 1272 time(s).
#2 Posted: 1/8/2015 9:02:33 PM
You must define a snippet shortcut to have a valid snippet, otherwise is just a smath worksheet in the snippet folder.
go to: File > Properties > File Atributes
Вячеслав Мезенцев 1/9/2015 3:57:00 AM
#3 Posted: 1/8/2015 11:04:02 PM
Ryan Freund
Ryan Freund
Someday that thank button will work... or not.
Thank you!
#4 Posted: 1/9/2015 11:39:29 AM
Ryan Freund
Ryan Freund
Your solution works and is better than what I was doing but it is still odd that when you use tools -> Snippet Manager that some files populate while other do not.
