Stable: SMath Studio 0.78 (01 March 2009)
Stable: SMath Studio 0.78 (01 March 2009) - Messages
#1 Posted: 3/1/2009 12:50:31 AM
New SMath Studio 0.78 Stable available
SMath Studio Handheld on the Smartphone
Quote
Controls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.
SMath Studio Handheld on the Communicator (PPC)
Last changes
  • SMath Studio now supports Mathcad files to open (files with .xmcd extension)!
  • Desktop: Dynamic cursor changes implemented (on the bounds of the controls, on resizing, on moving etc...);
  • Added ability to Undo/Redo for the hole page instead of the separate history for every control;
  • Selecting page controls with Ctrl key pressed implemented;
  • Desktop: Ctrl+M (Open Insert Matrix dialog), Ctrl+E (open Insert Function dialog) and Ctrl+T (insert picture control) shortcuts added;
  • To start writing a text " (quotes) button can be pressed;
  • Desktop: PI constant now can be inserted with a shortcut: Ctrl+Shift+P;
  • Desktop: Added ability to Zoom graphs by mouse wheel;
  • Desktop: added Drag & Drop ability to open files from the outside;
  • Desktop: Window params now save on programe close (such as: size and location);
  • Improved simplification of the functions ln(x) and lg(x) in case of the x-numbers are equal e (for ln) or 10^c (for lg);
  • Trigonometric functions with standard values in deg. now can be simplified;
  • Min required numbers changed from 10e-12 to 10e-99;
  • Fixed error with Plot control: sometimes it can't be resized.
  • sec() and cosec() [csc()] functions simplification ability added;
  • Numeric library improved to exclude some calculating errors;
  • identity(), matrix(), rows(), cols(), el(), length(), tr() functions implemented into symbolic library;
  • Vector multiplication (cross product) operator added to symbolic library for native support;
  • Loops (for, while) performance improved;
  • All symbolic calculations results now displays all fractional powers as radicals;
  • German interface translation updated;
  • Fixed error: calculation results not updates after using Undo/Redo functionality;
  • Handheld: Fixed error with various matrix Toolbar button modes on non-cyrillic devices;
  • Corrected file names of opened pages on the main program Title;
  • Fixed paths for the result html-file on Export to HTML action (especially for Linux version);
  • Graphs improved (summ() function now work into the control);
  • Border supporting added to SMath Studio controls;
  • Handheld: Fixed error when user "Save as" file without filling extension in File Name input - this file can rewrite existent one without any confirmation dialog;
  • Desktop: Fixed errors with Save-On-Close dialogs;
  • Text Control now can be removed by removing all it's text;
  • Fixed "Esc = Backspace" issue;
  • Desktop: 3D plot accuracy increased;
  • Fixed critical error, when Plot graphs with large z-coordinate;
  • Update dialog now can be setted up to check for stable updates only;
  • Couple of errors in symbolic library fixed;
  • Speed and stability improved;
  • Code optimizations.
System requirements
  • Handheld:
    Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, full VGA support, all PPC's, Comunicators and smartphones.
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
    Framework: Mono 2.0
Interface languages
Desktop и Handheld (18 languages):
  • [ENG] English / English
  • [GER] German / Deutsch
  • [DUT] Dutch / Nederlands
  • [SPA] Spanish / Español
  • [FRE] French / Français
  • [SCR] Croatian / Hrvatski
  • [SCC] Serbian / Srpski
  • [GRE] Greek / Ελληνικά
  • [CZE] Czech / Čeština
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [POL] Polish / Polski
  • [RUS] Russian / Русский
  • [BUL] Bulgarian / Български
  • [LTH] Lithuanian / Lietuvių
  • [UKR] Ukrain / Українська
    Free Download
    ** For installation of the program from PC it is necessary to install MS ActiveSync first.
