What is the matrix function to find the extrapolated value from a given 2-dimension table
What is the matrix function to find the extrapolated value from a given 2-dimension table - Messages
#1 Posted: 4/21/2021 4:46:53 PM
Tuan Nguyen
Tuan Nguyen
0 likes in 16 posts.
Is there such matrix function to help me get the coefficient Cf based on ratio s/h and B/s from given table in matrix form?
#2 Posted: 4/21/2021 5:38:34 PM
598 likes in 1,380 posts.
You can either use linterp() or InterpBilinear().
They can also find an interpolated value between title numbers.
Please look at the Reference Book for further information.
#3 Posted: 4/21/2021 6:05:55 PM
Tuan Nguyen
Tuan Nguyen
Thank you. Found it here. https://en.smath.com/forum/yaf_postst17672_Interpolate-Matrix.aspx
Learn new things every day.
#4 Posted: 4/21/2021 6:24:29 PM
Spline(M,x,y) is universal.
Construct 1/1 from the given example, forget decoration <, >
Just for interpolation, you don't need the rotation system.
Spline Matrix Tutorial RECTANGULAR Surface Plot.sm (22.98 KiB) downloaded 1168 time(s).
Tuan Nguyen 4/21/2021 7:04:00 PM
#5 Posted: 4/21/2021 6:33:04 PM
... nice example done for Smath Community visitor.
Construct rough data table, spline at will, plot is most delightful.
How do you manage ... Jean
SplineRectangularMatrix Isentropic Surface.sm (457.73 KiB) downloaded 1197 time(s).
#6 Posted: 4/21/2021 7:13:21 PM
Tuan Nguyen
Tuan Nguyen
Beautiful. I love the way you present all math problems in such a lovely form.
Even though it is a very rare case, when x and/or y values exceed the range in my posted table the function will return the value more or less than it should be because I think the table cap the values. I wanted to make changes to the Spline function to reflect this but my limited knowledge in programing and Smath prevents me from doing that. Any suggestions?
#7 Posted: 4/22/2021 1:50:04 PM
See you soon tomorrow ... Jean.
... here is, play with rotation.
Spline Matrix Tutorial RECTANGULAR Surface Plot Example.sm (23.4 KiB) downloaded 1208 time(s).
Tuan Nguyen 4/22/2021 2:42:00 PM
#8 Posted: 4/22/2021 2:47:20 PM
Tuan Nguyen
Tuan Nguyen
Awesome. When x=70, y=0.5, I need it to be 1.75 per code because x>45 but the function gives me 1.83. How would I modify the code for Spline to achieve this.
#9 Posted: 4/22/2021 3:37:25 PM
Obviously the function uses linear extrapolation beyond the limits of the data array.
Without touching the function you can enforce constant extrapolation by repeating the first or last rows or columns of data.
surface.sm (18.8 KiB) downloaded 1098 time(s).
Tuan Nguyen 4/22/2021 6:37:00 PM
#10 Posted: 4/22/2021 4:46:35 PM
... as simple as that, preserving last two cols linearity.
#11 Posted: 4/22/2021 6:41:11 PM
Tuan Nguyen
Tuan Nguyen
Me feeling dumb. Thanks, Jean and MKraska
