Positioning of expression stops recalculation
Positioning of expression stops recalculation - It appears that positioning the expression before defining variables affects output - Messages
#1 Posted: 11/24/2020 7:49:50 PM
Mark Berelowitz
Mark Berelowitz
0 likes in 1 posts.
File not found.File not found.File not found.
In the first case, the variables are defined, and then the expression, then the variables are changed, but the result doesn't update with recalculate.
In the second case, the expression is defined before the variables. When changing the variables, the result updates.
Why does this happen?
Thanks
Mark
#2 Posted: 11/24/2020 8:53:03 PM
churichuro
churichuro
28 likes in 79 posts.
in the first case you are defining the values and then an expression,
the expression is evaluated and no longer depends on the external variables ...
while in the second case you are defining a function without parameters,
so in this second case the value changes as you change the value of your variables.
#3 Posted: 11/24/2020 11:08:17 PM
983 likes in 6866 posts.
Better work algo style !
