Cant find "range" feature
Cant find "range" feature - Messages
#1 Posted: 5/4/2009 7:27:37 AM
riddler
riddler
0 likes in 3 posts.
Hi there,
first of all thanks a lot for the awesome software.
It seems to be exactely what I was looking for, but I have a problem with a certain function I can use in MathCAD but can not find in SMath.
When I have a funktion of d and I would like to get the calculated results of that function for d being 0,100..1000
In MathCAD it would look like:
f(d)= blablabbla
d=0,100..1000
with the result be presented in a table
f=f(d=0)
f(d=100)
f(d=200)
f(d=1000)
A sample was linked in the forum already, but HERE it is again
Maybe somebody can help me.
#2 Posted: 5/4/2009 10:41:09 AM
Hello.
We're still working to implement Range function to SMath Studio. Hope, this work will be finished till next release.
#3 Posted: 5/4/2009 1:48:06 PM
riddler
riddler
0 likes in 3 posts.
Thanks for the answer - after a bit more forum browsing I found that I was not the first one who is missing the feature.
Anyway, I am trying to get a graph showing a function that depends another function, but I just do not get it to work.
Maybe somebody can help - because I do not want to spend any more hours in fiddling.
I have created a sample file which you can find HERE
#4 Posted: 5/4/2009 2:32:32 PM
I have downloaded your file and have opened it with SMath Studio 0.80. Here is screen:
#5 Posted: 5/4/2009 2:38:46 PM
I don't know what localization of the program you use, so in some cases you should use sh() instead of sinh(). Try to change this function. the second way: you can change options of the program to accept sinh():
And after you will change it you should recalculate page via main menu:
#6 Posted: 5/4/2009 8:33:49 PM
jakobg
jakobg
0 likes in 21 posts.
Hi Riddler,
I also tried your file and there are three problems I've found:
1. you need to define n1
2. to make T vs d you have to use the following syntax: T(d)=...sinh(y(d)) ... I tried this and it worked.
3. The function you intend to plot leads to 1/infinity (since sinh of a huge number is more or less infinity), and as you defined d has to be something the size of 10^-7 to keep values of T in a reasonable order of magnitude. But there is currently no possibility to define the plot borders so, actually it is impossible to plot this function!
--> @ smath:
I tried to use the limit tool but I wasn't able to derive lim d->1 T(d)=0 ?
Anyway, nice feature with the symbolic calculation in the tooltips!
Jakob
#7 Posted: 5/5/2009 6:48:00 AM
riddler
riddler
0 likes in 3 posts.
Hi Jakob,
thanks for the help.
I figured that out later, it was just a in the sample file - which I have made a bit simpler to show my problem a bit more clearly.
I have now added it, and it seem to work in deed. When writing T(value of d)= it gives a correct result.
That is the remaining problem. If one actually zooms in a lot, you can see, that it plots something, but since the values of d (x-axis) is extremely small - the plot is more or less useless.
I have uploaded the corrected file and you can find it under the link from my previous post. If anybody knows how to get a useful plot out of the data, my problems (for now) would be solved.
#8 Posted: 5/5/2009 7:40:54 AM
jakobg
jakobg
a possibility I forgot yesterday is to scale the value of d. Try T(d)=...y(d/10^7), then you can plot he whole function and the x-Axis shows the Numbers 0 to 5 (times 10^-7).
Ciao
