Variable plotting
Variable plotting - Messages
#1 Posted: 4/23/2023 8:06:08 AM
JJJ
JJJ
0 likes in 13 posts.
Hello to everybody,
I am trying to represent a graph where arguments include units. I have seen that it is necessary to divide these variables by their units to do it. I want to know about the possibility to not to do this, because I want to change the input units and it is a quite complicated to be dividing the units in the next lines.
Thank you.
JJJ
#2 Posted: 4/23/2023 3:34:47 PM
Not sure what you want w/o Smath document.
#3 Posted: 4/24/2023 10:42:19 AM
⚜ Kenny Lemens, P.E. ᵂᴵ
85 likes in 180 posts.
Greetings,
Dividing units out may be the best option, otherwise the units on your graph will default to base units (that is, if you get units to work as expected). But, just be aware that there are plugins that may produce the graph you are interested in; You can explore the other posts on this forum for some insight:
You can check out these forums:
- https://en.smath.com/forum/yaf_postst21520_X-Y-Plot-for-electrical-resistance.aspx
- https://en.smath.com/forum/yaf_postst20103_Plotting-with-2D-plot.aspx
- https://en.smath.com/forum/yaf_postst4455_Interaction-Diagram-for-Rectangular-Reinforced-Concrete-Sections--ACI-318.aspx
May this be of Good Help,
SK Kenny Lemens, P.E. ᵂᴵ
