Stable: SMath Studio 1.5.0.9678 (01 July 2026) - Messages
SMath Studio
Changes introduced in current build 1.5.0.9678
Improvements
- The 'Open with' context menu now distinguishes between Solver and Solver Enterprise, and also supports Writer;
- Added tooltips to the Bold, Italic, and Underline toolbar buttons;
- Added the ability to install a plugin from a file using the appropriate button in the Plugins view of the Extensions Manager;
- Added the following math functions: ceil() and floor().
Corrections
- Restored functionality of the Bold, Italic and Underline toolbar buttons;
- Restored the click functionality for the 'Company Name' item in the main menu;
- Restored tooltips on the status bar;
- Fixed the unresolved 'ProductName' property in the MSI package;
- Fixed data copying from MathRegion to preserve the current input state (fixes index input in Cloud version of SMath Studio);
- Fixed an issue where creating a region from the Custom Region plugin returned null: a missing region is now created instead of throwing an unhandled exception;
- Updated the tag list for the SMathStudio.Core.Refs and SMathStudio.Plugins.Refs NuGet packages;
- Fixed an exception that occurred during Picture Region serialization due to an incorrect image format;
- Fixed bitmap image loading by detaching the image from the input memory stream.
Miscellaneous
- The main SMath Studio executables are now equipped with standard File Description and Product Name properties;
- The 'Page Setup' menu item is now disabled when no worksheets are open;
- Removed the unused link button from the Extensions Manager;
- Reworked the plugin installation code to avoid deleting files and folders during plugin installation;
- Added a new optional command-line parameter -l (-launch) supporting the PluginLoad=Sequential option (allows loading plugins sequentially) and SkipThirdParty (allows loading only standard plugins);
- License dismissal is now synchronous to ensure it executes correctly during application shutdown;
- Removed the Translator URL from the Extensions Manager;
- Corrected the Russian translation;
- Corrected the tag list for the SMathStudio.Drawing NuGet package.
Download
SMathStudioDesktop.1_5_0_9678.Mono.tar.gz (2.2 MiB) downloaded 5199 time(s).
SMathStudioDesktop.1_5_0_9678.Setup.msi (3.38 MiB) downloaded 65959 time(s).
SMathStudioDesktop.1_5_0_9678.x86_64.astra-orel.glibc2.24.AppImage (10.21 MiB) downloaded 2470 time(s).
SMathStudioDesktop.1_5_0_9678.x86_64.ubuntu-22_04.glibc2.35.AppImage (12.67 MiB) downloaded 3134 time(s).
SMathStudioDesktop.1_5_0_9678.x86_64.ubuntu-24_04.glibc2.39.AppImage (12.39 MiB) downloaded 3554 time(s).
