SMath new file loading mode
SMath new file loading mode - New page or new SMath instance for a new application - Messages
#1 Posted: 9/9/2024 5:26:53 PM
ioan92
ioan92
171 likes in 104 posts.
When I have already loaded an application in SMath and I want to load another application, the last one is always loaded as a new page and not as a new instance of SMath.
Sometimes (only), I want that the new application to be loaded in a new instance of SMath instead of a new page. How could I handle this option.
The reason for my demand is based on the intention of being able to run two or more applications on different screens of the same computer.
Thank you for your attention,
Ioan
#2 Posted: 9/9/2024 7:09:13 PM
StvMath
StvMath
43 likes and 1 dislikes in 68 posts.
Just start another instance of SMath first, then load the other application in that.
ioan92 9/9/2024 7:28:00 PM
#3 Posted: 9/9/2024 9:45:47 PM
ioan92
ioan92
Thanks,
It's perfect !
#4 Posted: 9/10/2024 9:48:42 AM
oscar mauricio
oscar mauricio
1 likes in 10 posts.
I normally don't start two instances of the application because when closing one of the instances an error is generated in the images inserted with the ImageRegion plugin of the instance that remains open.
I hope you can fix this.
#5 Posted: 9/10/2024 2:54:33 PM
1,434 likes in 2,912 posts.
I've found where is the issue, I can fix it.
ioan92 9/10/2024 5:43:00 PM
#6 Posted: 9/10/2024 6:48:04 PM
Fixed. Seems that the Release manager doesn't work currently, so the plugin can't be updated, but the code is uploaded in the SVN.
The temporary folder that contains the images generated on the fly by the plugin now has a sub-folder for each instance of the program, therefore the issue shouldn't arise anymore (BTW probably it was already reported before).
oscar mauricio 9/10/2024 7:32:00 PM, ioan92 9/10/2024 8:37:00 PM
#7 Posted: 1/11/2025 2:43:26 AM
Plugin updated
3 users liked this post
Andrey Ivashov 1/11/2025 4:26:00 AM, sergio 1/11/2025 4:19:00 PM, Alvaro Diaz Falconi 1/12/2025 3:48:00 PM
