Fixed. In your definition of Pu_Mu right above you had M.u instead of M.U. Not sure why it cause a crash. But now it runs.
Masonry - STR - Out-Of-Plane - Wall - V1.sm (198.27 KiB) downloaded 1299 time(s).FYI, the way I fixed this was to disable auto calculation. Then I scrolled down and disabled evaluation of each graph. I enabled the graphs one at a time and manually recalculated each time. The left one caused the crash. When I only enabled the right graph, it produced the error showing M.u was undefined. Then I could find the bad definition from there.
