1 Pages (2 items)
Modeling an Air Defense System: Ballistic Target Interception - Messages
#1 Posted: 3/31/2026 3:01:53 PM
It’s a mathematical model of an Air Defense System intercepting an unguided ballistic target, complete with an animated XY-plot.
Here is a quick overview of the math and physics inside the model:
- The Target (Blue trace): Modeled as a projectile launched at 700 m/s at a 60° angle. Its flight is governed by 2nd-order ODEs accounting for gravity and aerodynamic drag (using an exponential air density model based on altitude).
- The Missile (Red trace): Launched from a distance of 15 km with a constant speed of 350 m/s. It uses a continuous "Pure Pursuit" guidance law, meaning its velocity vector is constantly updated in the ODE to point directly at the target's current coordinates.
- The Core Logic: Instead of calculating the trajectories separately or using discrete loops, both the target's physics and the missile's guidance logic are unified into a single system of differential equations. The entire engagement is solved simultaneously using the built-in rkfixed solver.
- Launch Delay: The missile equations include a launch delay condition (t0 = 8 s) so the missile waits for the target to enter the optimal engagement zone.
I've attached the .sm document along with a GIF animation of the result.
You can play around with the launch delay (t.0), missile speed (v.r), or launch angle to see how the interception trajectory changes.
air-defense.sm (26.84 KiB) downloaded 582 time(s).
air-defense.pdf (86.6 KiB) downloaded 417 time(s).
Edited 3/31/2026 9:21:41 PM
4 users liked this post
ioan92 3/31/2026 5:55:22 PM, Valery Ochkov 3/31/2026 11:22:19 PM, overlord 4/1/2026 9:31:46 AM, santiago 4/9/2026 11:51:13 PM
#2 Posted: 4/2/2026 10:45:34 AM
You can learn about the problem and its solution from the article
V.F. OCHKOV, I.E. VASILEVA
APPLICATION OF DIFFERENCE SCHEMES TO DECISION THE PURSUIT PROBLEM
https://ia.spcras.ru/index.php/sp/article/view/4041/2619
1 Pages (2 items)
