1 Pages (4 items)
h(p1, p2) implicit plot - Why I can not create it? - Messages
#1 Posted: 6/19/2024 6:34:29 PM
#2 Posted: 7/22/2024 2:59:18 PM
2RegP-Ideal-Cool_Prop.sm (82.18 KiB) downloaded 1563 time(s).scratch geometry dash
The graph you've provided seems to show a relationship between two pressures 𝑝1and 𝑝2, with annotations related to efficiency calculations.
Axes:𝑝1 on the x-axis (measured in atm). 𝑝2 on the y-axis (measured in atm).
Curves: Different colored curves (red, blue, and green) that might represent different states or processes in a thermodynamic cycle or system, such as isobars, isotherms, or other state transitions.
Water/Steam Cycle: Given the mention of "WaterSteame Pro," this graph might be related to a water/steam cycle analysis, such as a Rankine cycle or steam turbine efficiency calculation.
Efficiency (𝜂): The efficiency calculations likely relate to the performance of a particular component or the overall system under different pressures and temperatures.
The mention of "points > 20 - problems" suggests there might be issues with the data points or calculations when exceeding a certain number of data points.
Valery Ochkov 7/22/2024 5:02:00 PM
#3 Posted: 7/24/2024 1:29:16 PM
Hi. You can use the Draghilev's method for parametrize a curve.
2RegP-Ideal-Cool_Prop (1).sm (82.56 KiB) downloaded 1491 time(s).
2RegP-Ideal-Cool_Prop (1).pdf (317.07 KiB) downloaded 882 time(s).
#4 Posted: 8/5/2024 1:51:05 PM
1 Pages (4 items)
