Beta: SMath Studio 0.99.6984 (14 February 2019)
Beta: SMath Studio 0.99.6984 (14 February 2019) - Messages
#1 Posted: 2/14/2019 5:00:49 PM
2,343 likes in 4,043 posts.
SMath Studio
Changes introduced in current build 0.99.6984
Improvements
  • Added ability to clone regions by Ctrl+Dragging by mouse inside Header/Footer.
Corrections
  • Insert Function dialog performance significantly increased;
  • SS-4583: Worksheet rendering issue fixed.
Miscellaneous
  • Regions movement related issues fixed;
  • Overall application stability increased;
  • Refactoring.
Download
SMathStudioDesktop.0_99_6984.Mono.tar.gz (1.36 MiB) downloaded 2183 time(s).
SMathStudioDesktop.0_99_6984.Setup.msi (2.23 MiB) downloaded 4293 time(s).
7 users liked this post
Davide Carpi 2/18/2019 8:37:00 PM, frapuano 2/14/2019 7:20:00 PM, NDTM Amarasekera 2/15/2019 2:27:00 AM, Radovan Omorjan 2/15/2019 2:57:00 AM, Serg 2/15/2019 3:13:00 AM, sergio 2/15/2019 5:57:00 AM, Вячеслав Мезенцев 2/14/2019 5:48:00 PM
#2 Posted: 2/15/2019 3:29:02 AM
genf
genf
6 likes in 72 posts.
Спасибо. Теперь функции работают значительно быстрее.
Вернулась старая проблема с настройками страницы - не сохраняются настройки при нажатии на кнопку "Использовать по-умолчанию".
Вернее они для файла сохраняются, но показывает, что не сохранились.
А вот глобально не сохраняются.
Небольшое кино
#3 Posted: 2/15/2019 6:48:04 AM
fedeghi
fedeghi
25 likes in 112 posts.
Hi Andrey,
since I'm using SMath mainly for office work, I'm always struggling between the temptation of "instant updating" to the latest (even if beta) build in order to have all the new cool features, and the conservative approach to wait for the official stable release and stay safe with my library of .sm files.
Up to now, I have been able to resist and stay on the safe path, but the "dark side is calling"
Recently a lot of nightly builds have been issued, so I'm wondering if you are planning to upload in a short time a stable release to consolidate all the updates that have been placed here and there in the betas?
Or do you think that a stable release will not follow shortly?
In other words, in case a stable release is not planned in the upcoming weeks, I might think to update on a backup machine and test the existing files there.
Infact, there are some features which I'd like to use (i.e. upgraded syntax highlighting, etc..)
#4 Posted: 2/15/2019 6:53:08 AM
You can always download the Mono.tar.gz package and go for a portable test version
Serg 2/15/2019 9:09:00 AM
#5 Posted: 2/15/2019 9:10:40 AM
genf
genf
Да, это действительно удобно. Портативную версию уже использую лет 5
#6 Posted: 2/15/2019 2:13:20 PM
Так а сохранение размера бумаги я и не делал Сохраняется только ориентация страниц, колонтитулы и т.п. С размером были какие-то проблемы. Как-нибудь посмотрю туда ещё раз...
#7 Posted: 2/15/2019 2:29:16 PM
Hello.
The reason of why we have so many beta versions since latest available stable is that there are several major changes were done to the logic of saving/opening files and rendering Worksheets.
These changes must be tested well before going to the wild world
As for today I see no any new significant errors reported + all automated tests I have are also passed ok, so I'm thinking about latest nightly builds as about release candidates. These versions seems stable enough to use them.
Regarding next stable release - I plan to publish it on 1-st March. The main reason of it is that I need to test/prepare Cloud version as well as iOS/Android/UWP versions to make one-shot-release. There are plenty of work to perform...
3 users liked this post
Serg 2/15/2019 3:03:00 PM, sergio 2/15/2019 3:25:00 PM, frapuano 2/15/2019 2:54:00 PM
#8 Posted: 2/15/2019 6:25:24 PM
fedeghi
fedeghi
Thanks for the info! :d
#9 Posted: 2/18/2019 3:06:04 PM
Реализовано тут: https://en.smath.com/forum/yaf_postst17120_Beta--SMath-Studio-0-99-6988--18-February-2019.aspx
Serg 2/25/2019 3:15:00 PM
#10 Posted: 2/25/2019 3:29:20 PM
genf
genf
Бывает в версии 6984 при открытии файла происходит очень долгий расчет ... приходится прерывать и обновлять - при обновлении все быстро считается.
См. кино
Как правило такие долгие расчеты происходят при первом открытии файла, но не всегда.
Это исправлено в 6988?
