... this document illustrates the 3 types cubic splines:
linear, parabolic, cubic for eventual end use.
1. Assume a physical project evaluates @ points.
2. Assume this project has become a STANDARD.
3. Assume it has been populated 'cubic linear'.
4. Assume your Smath project is OK but can't be
made scalar like in [1.]
5. @ this point if you can't populate 'cubic linear'
6. Then, your project does NOT meet the STANDARD.
An example is the Mathcad ODEsolve from linear cubic.
Native Smath can't render from cinterp.
Cheers ... Jean.
Maths EDU Reconciliation [l_p_c_splines] READ FIRST Copy.sm (125.06 KiB) downloaded 1235 time(s).
