Arch Linux doesn't display greek characters on button in the left side
Arch Linux doesn't display greek characters on button in the left side - Messages
#1 Posted: 9/13/2018 9:37:25 AM
andrea993
andrea993
2 likes in 12 posts.
It doesn't show me greek characters in right side buttons, it show some rectangles. In worksheet greek characters works.
#2 Posted: 9/13/2018 11:49:04 AM
598 likes in 1,379 posts.
Same here for a very long time. I have installed several font packs but couldn't succeed.
To be honest, somehow I did used to this issue. Yet sometimes I click several buttons to find correct letter
#3 Posted: 9/13/2018 6:27:13 PM
Please try this build: http://smath.info/file/yaoVu - if Greek chars will be shown ok I will include the fix into the next stable version of SMath Studio.
Thank you in advance!
#4 Posted: 9/14/2018 3:53:50 AM
andrea993
andrea993
Nope, this build doens't start on my system, I think that I miss some font but I don't know which, the version you link me abort with this error:
Unhandled Exception:
System.Exception: Can't find a proper language file. Try to reinstall the program.
  at SMath.Manager.SessionsManager.ReloadLanguages () [0x00060] in <cc3205659b864dac8764824a4bc9a689>:0
  at SMath.UI.SessionsManagerPaths.Create (System.String[] paths) [0x0001d] in <25490bd212e14fd0a47fd12bfc12ca47>:0
  at SMath.UI.AppSettingsDesktop.Initialize (SMath.Manager.PluginsStatusEventHandler loaded) [0x0005e] in <25490bd212e14fd0a47fd12bfc12ca47>:0
  at SMath.UI.Desktop.Program. (System.String[] ) [0x0005b] in <a5ff19d5461b4be49f91c8081ba62fc2>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.Exception: Can't find a proper language file. Try to reinstall the program.
EDIT: I see that I have the same error with beta version 0.99.6824, only the stable version 0.99.6671 and older work for me
#5 Posted: 9/14/2018 1:44:56 PM
Thank you! Yeah, this was an error in latest beta. Just fixed it.
I think now everything should work as expected, please test: http://smath.info/file/TR8Ne (I've tested it successfully on Ubuntu 18.04.1)
Best regards, Andrey Ivashov.
overlord 9/15/2018 5:52:00 AM
#6 Posted: 9/14/2018 2:12:28 PM
andrea993
andrea993
Ok this version solved the greek issue but there is a new problem, on startup it say me to update some plugins (I think because new version need new plugins version) but if I click on update the program crash with this error:
System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
  at System.Collections.ArrayList+ArrayListEnumeratorSimple.MoveNext () [0x00013] in <815942dd495d4ccc954b977c1d4bee11>:0
  at System.Windows.Forms.Hwnd.AddInvalidArea (System.Drawing.Rectangle rect) [0x00037] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.Hwnd.AddInvalidArea (System.Int32 x, System.Int32 y, System.Int32 width, System.Int32 height) [0x0000b] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.XplatUIX11.AddExpose (System.Windows.Forms.Hwnd hwnd, System.Boolean client, System.Int32 x, System.Int32 y, System.Int32 width, System.Int32 height) [0x00057] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue, System.Boolean allowIdle) [0x002ec] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.XplatUIX11.UpdateMessageQueue (System.Windows.Forms.XEventQueue queue) [0x00000] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.XplatUIX11.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr handle, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x0001c] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.XplatUI.GetMessage (System.Object queue_id, System.Windows.Forms.MSG& msg, System.IntPtr hWnd, System.Int32 wFilterMin, System.Int32 wFilterMax) [0x00000] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.Application.RunLoop (System.Boolean Modal, System.Windows.Forms.ApplicationContext context) [0x0034e] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.Application.Run (System.Windows.Forms.ApplicationContext context) [0x00011] in <206d6d7865674caba761ab5f5b301dc0>:0
  at System.Windows.Forms.Application.Run (System.Windows.Forms.Form mainForm) [0x00006] in <206d6d7865674caba761ab5f5b301dc0>:0
  at .. () [0x0000a] in <7855f2562e4d4c67b6d2fafcf667b6ab>:0
  at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) [0x00014] in <815942dd495d4ccc954b977c1d4bee11>:0
  at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00071] in <815942dd495d4ccc954b977c1d4bee11>:0
  at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncCtx) [0x00000] in <815942dd495d4ccc954b977c1d4bee11>:0
  at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) [0x0002b] in <815942dd495d4ccc954b977c1d4bee11>:0
  at System.Threading.ThreadHelper.ThreadStart () [0x00008] in <815942dd495d4ccc954b977c1d4bee11>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
Andrey Ivashov 9/14/2018 4:31:00 PM
#7 Posted: 9/15/2018 5:50:27 AM
well, this version just works for me. no greek letters issue except the title of alphabet panels, no error for plugins.
good job, thanks for your quick action.
regards
