element-wise matrix operations
element-wise matrix operations - Messages
#1 Posted: 10/21/2010 9:20:56 PM
iveyj1
iveyj1
0 likes in 2 posts.
Folks,
Is there a way to cause matrix operations to be performed
element by element? For example if two matrices are
multiplied, the top-left element of the multiplicand
would be multiplied by the top-left element of the multiplier
and placed in the top-left element of the product, and
so on. In mathcad this can be done by pressing -
(vectorize).
Thanks,
Jack
#2 Posted: 10/22/2010 2:00:06 AM
No, there is no element-wise matrix operations in Smath (like vectorize in Mathcad). You just have to use loops (for, while) to perform such operations.
#3 Posted: 10/22/2010 9:19:06 PM
iveyj1
iveyj1
0 likes in 2 posts.
Ok, thanks for the quick response.
Is it possible to add operators via the plugin
mechanism or would that require a change to the core?
The reason I am interested in this functionality
is that I use it heavily in Mathcad to perform
similar calculations on a set of variables. The for
loop provides a similar functionality, but
the visual presentation is much more awkward,
unless I am missing something.
By the way, this is one of the best and most needed free
software I have come across.
Thanks,
Jack
#4 Posted: 9/22/2025 9:11:58 AM
Gerhard
Gerhard
0 likes in 1 posts.
Haha, 15 years later, I'm facing the same problem. For my calculation of screw forces, I need the square distances of my screws and thought I could calculate them element by element.
Then I'll have to try to write a for loop.
#5 Posted: 9/22/2025 9:51:35 AM
federico
federico
6 likes in 8 posts.
"Vectorize" is available and, if I understood your request, it should work for your use case without need of any loop.
