Frame and Beam analysis with Moment distribution method
Frame and Beam analysis with Moment distribution method - Problem with Array - Messages
#1 Posted: 2/22/2023 9:03:54 AM
yoswos
yoswos
0 likes in 6 posts.
I have been trying to convert this Smath Studio file to Mathcad
and I have gone this far but found an error that said
"This Array index is invalid for this array."
Please comment on it.
Thanks.File not found.File not found.
#2 Posted: 2/22/2023 10:36:44 AM
Mathcad index starts 0 ... Smath 1
Your Smath document turns red Syntax is incorrect.
To be doctored ... so immense !
#3 Posted: 2/22/2023 3:49:29 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
The SMath program you are referring was posted sometime back to the FORUM by me.
It was based on the moment distribution method, and use of it is limited only to
cases of 2 span substitute frames.
Recently, I posted a couple of examples based on the stiffness method. which can
be used for any practical number of spans.
See the following link.
https://en.smath.com/forum/yaf_postsm80558_RC-Subframe-Analysis-by-Stiffness-Method.aspx#post80558
I have redone your example using this stiffness method, attaching it with a definition file.
These two files must be in the same folder please.
Unfortunately these two sm files are lengthy, and I sincerely welcome forum members
to propose any improvements.
I am extremely sorry that I am unable to check your example Mathcad file.
Cheers,
Include_Programs-R10.sm (118.66 KiB) downloaded 1139 time(s).
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method.sm (387.81 KiB) downloaded 1267 time(s).
Davide Carpi 2/23/2023 10:06:00 AM
#4 Posted: 2/23/2023 12:40:11 AM
NDTM Amarasekera
NDTM Amarasekera
Above example simplified to show only the Support and Column Moments.
Definition file not required.
Cheers
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.sm (232.84 KiB) downloaded 1304 time(s).
MacGinley and Choo_Ex_13.1_TO_FORUM-STIFFNESS Method-R1.pdf (333.69 KiB) downloaded 754 time(s).
#5 Posted: 2/23/2023 9:49:58 AM
yoswos
yoswos
0 likes in 6 posts.
Thank you.
#6 Posted: 2/23/2023 11:29:51 AM
NDTM Amarasekera
NDTM Amarasekera
Davide Carpi 2/23/2023 3:14:00 PM
