Repetitive calculations
Repetitive calculations - Estructure repeat - Messages
#1 Posted: 9/21/2023 7:14:35 PM
daniel
daniel
1 likes in 6 posts.
Good morning, my dears, could you help me? Recently, I have been learning programming in smath. My question is whether it is possible to make a multiple input in a repetition structure, whether it is a For... That is, an example if I had several geometric figures, for example, a triangle with different measurements, let's put a number that is 100 triangles with different measurements and I would like to program with the help of a repetition structure to instruct the dimensions of each triangle to find its area
Example
For I from 1 to N Do
Input(B, H) ;
Area_(I)=0.5*B*H
End;
Is there a way to do this in smath?
mod edit: please give your threads proper titles; this help yourself to receive more, better and faster answers, and you won't be erroneously mistaken for a spammer.
#2 Posted: 9/22/2023 7:17:05 AM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
...let's put a number that is 100 triangles with different measurements and I would like to program with the help of a repetition structure to instruct the dimensions of each triangle to find its area
Example
Input(B, H) ;
Area_(I)=0.5*B*H
End;
Hi Danuko, maybe an easy way to do you need is program a simple function and define the input as a matrix:
and here is the file: TriangleAreas.sm (5.6 KiB) downloaded 1196 time(s).
Best,
Oscar
daniel 9/22/2023 10:47:00 AM
#3 Posted: 9/22/2023 9:28:28 AM
1,355 likes in 2,270 posts.
I wonder whether you really want to input hundred of triangle specifications inside SMath.
Using matrices for input usually is a nightmare because you neither can insert rows nor can you delete ones without resorting to some programming.
You could, however, build a sort of editor with append, insert, delete functions for the data storage.
I'd prefer a multicolumn text file (e.g. csv format) and the use of the importData() function.
Oscar Campo 9/22/2023 9:36:00 AM, daniel 9/22/2023 10:47:00 AM
#4 Posted: 9/22/2023 2:23:54 PM
As suggested Post # 3, you can manipulate
your long rectangular triangles dimensions.
Those offered algo style collapsed.
Zillions.sm (34.43 KiB) downloaded 1227 time(s).
#5 Posted: 9/22/2023 4:49:59 PM
You can even construct random or on some governing function.
All those single output values, can you pass to a music system ?
