1 Pages (6 items)
Units in dynamic created matrix - Messages
#1 Posted: 12/4/2020 7:19:18 AM
I created a dynamic matrix as T := matrix(2, cols(T1)). The values of the T1 matrix have units [MPa]. The values have to be rewritten to T where they meet certain requirements. But values of the "new" matrix T have units [kg/m*s2]. Is it possible change thise units to [MPa]? Any attempt to change units fails because the matrix T is computed.
Thank for any advice
Jadalbert
Jadalbert
#2 Posted: 12/4/2020 8:45:15 AM
WroteI created a dynamic matrix as T := matrix(2, cols(T1)). The values of the T1 matrix have units [MPa]. The values have to be rewritten to T where they meet certain requirements. But values of the "new" matrix T have units [kg/m*s2]. Is it possible change thise units to [MPa]? Any attempt to change units fails because the matrix T is computed.
Jadalbert
Not sure if I understood but you could show whatever unit is suitable (and consistent) by changing the unit of measure in the displayed results.
Same you would do with a single result, you can change the displayed unit in the black rectangle after results.. only difference from a single formula, is you need to use adiagonal matrix with proper units in proper positions.
At least, this is what I'm often doing to have a clearer view.
Some other users on the forum don't like using/displaying units at all, but that's another separate and recurring topic I guess.
sergio 12/5/2020 6:34:00 AM
#3 Posted: 12/4/2020 9:11:31 AM
It works! Tkank You.
In my case now it looks like:
T := [1 2 3 4 ...] MPa
and that is what I wanted.
#5 Posted: 12/7/2020 8:26:00 AM
Thakn you Jean Giraud. I wil try use you advice.
#6 Posted: 12/7/2020 9:37:01 AM
... suggestive examples.
Table Scientific.sm (20.56 KiB) downloaded 1126 time(s).
Table Medic Data.sm (17.51 KiB) downloaded 1135 time(s).
Inst_Colebrook Pipe Data.sm (71.4 KiB) downloaded 1155 time(s).
1 Pages (6 items)
