1 Pages (5 items)
Speeding up calculation time for Monte Carlo simulations - Messages
#1 Posted: 12/1/2023 4:41:02 AM
Hi all, I don't even know if this is possible, but I figured I would ask anyways to see if someone might know any tricks.
I wrote a worksheet to show my students an example of a method for making probabilistic calculations of a parameter instead of using deterministic methods. The probabilistic calculation using Monte Carlo simulation lends itself to calculating probability of failure, which is a nice way of explaining system reliability.
Ideally, one would run a large number of simulations so that the result converges. However, it seems like the matrix calculations (or at least the way I am doing them) are quite slow, and when I assign a meaningful number of trials (say, 1000 or more), it takes the worksheet forever to calculate. I can do the same in Excel and it is almost instantaneous to do even 10000 or 20000 trials, but I hate doing these in Excel since I can show the work and the equations much more easily with SMath.
Any suggestions on what might speed up the run-time? The worksheet is attached for reference.
Thanks!
FT
Correlated Normal Variables - Bearing Capacity Example.sm (417.53 KiB) downloaded 1498 time(s).
Thanks!
FT
#2 Posted: 12/1/2023 4:51:42 AM
You just have to switch all cells to numeric optimization (Ctrl A to select everything, right mouse button on any cell, select Optimization> Numeric
Then, with 10000 tries it took a couple of seconds on my 6 years old notebook.
Correlated Normal Variables - Bearing Capacity Example_Kr.sm (417.97 KiB) downloaded 1518 time(s).
sergio 12/1/2023 5:43:00 PM
#3 Posted: 12/1/2023 4:55:34 AM
And there it is, easy as that
Thank you so much!
WroteYou just have to switch all cells to numeric optimization (Ctrl A to select everything, right mouse button on any cell, select Optimization> Numeric
#4 Posted: 12/2/2023 1:35:02 AM
WroteAny suggestions on what might speed up the run-time? The worksheet is attached for reference.
The attached document runs Monte-Carlo in two styles.
1. Logistic style 4 s
2. Ordinary style 0.7 s
Observe eval(,)
Stat Monte Carlo [rlogis] Copy 2.sm (102.24 KiB) downloaded 1261 time(s).
#5 Posted: 12/2/2023 1:45:46 AM
Thanks for sharing, looks like it will be useful!
WroteWroteAny suggestions on what might speed up the run-time? The worksheet is attached for reference.
Observe eval(,)
1 Pages (5 items)
