Default filetypes
Default filetypes - Messages
#1 Posted: 6/24/2019 7:48:14 PM
Dionysios J. Pantazis
16 likes in 180 posts.
Andre et all-
Would you consider adding an option box for the default file save type? I would like to set SMath to default to .smz instead of .sm. I realize that I am probably in the minority but want to throw it out there.
Thanks
sinneD
#2 Posted: 6/25/2019 9:13:28 AM
Once you have constructed the Smath document, including miscellaneous stuff "files".
you can save *.sm or *.smz
Then isn't true that at re-opening *.smz you recover the file stuff as well ?
#3 Posted: 6/25/2019 10:54:21 AM
... on the other hand: not every/any Smath piece can be saved to file ...
i.e: the collector { can't be saved to file,
saved it otherwise vector style.
