Stable: SMath Studio 0.89 (23 July 2010)
Stable: SMath Studio 0.89 (23 July 2010) - Messages
#1 Posted: 7/22/2010 10:17:31 PM
2270 likes in 3734 posts.
New SMath Studio 0.89 Stable available
SMath Studio Handheld on the Smartphone
Quote
Controls:
With consecutive pushing of this button you can choose: "1", delimiter of the number ",", "square root - sqrt", "n-th root - nthroot", "integral - int", "function to find roots of equations - solve". To lock any variant just stop pushing this button 1 second.
SMath Studio Handheld on the Communicator (PPC)
Last changes
  • Added support for subscript in variables, units and functions;
  • Functional programming feature implemented;
  • Keystrokes added to allow text regions formatting: Ctrl+B (bold switcher), Ctrl+I (italic switcher) and Ctrl+U (underlined switcher);
  • Ctrl+Insert and Shift+Insert keystrokes implemented;
  • Right button after the left part of evaluated expression now brings cursor to the Units placeholder;
  • Added ability to modify name of the created functions without removing it;
  • Added ability to automatically highlight repeated variables inside the Math region;
  • Multiple-rename functionality implemented using F8 keyboard button;
  • SMath Studio Live link added on the main menu under "Help" section;
  • Added ability to remove Arguments Separators of the functions using Backspace keyboard button;
  • ksi, ksf, rpm and radpm units implemented;
  • Réaumur scale Unit name changed to "°Re" (from "°R");
  • Insert Unit Dialog keystroke changed to Ctrl+W;
  • Calculation menu actions improved;
  • Accuracy of calculations with "e" and "pi" constants improved;
  • Accuracy of calculations with a numeric sin(..), cos(..), tan(..) and cot(..) functions improved;
  • XMCD file type support plugin updated in order to support strings inside math regions and variables/functions with literal subscript;
  • Added ability to paste operands into the other operands within the math Control;
  • Dynamic Assistance feature improved to show user-defined variables before built-in units with the same names;
  • Dynamic Assistance items list now hides on error in the math region;
  • Values of built-in variables/parameters are included to the Dynamic Assistance list;
  • Fixed issue when Dynamic Assistance items list was not shown or its location was wrong;
  • Desktop: Restrictions to insert matrix more then 100*100 using the Insert Matrix dialog modified to 10000*10000;
  • Desktop: Quick search of the non-linear units using Insert Unit dialog fixed - now search is not case-sensitive;
  • Example file Translator info now shown into the Examples Dialog;
  • New example included: Gravitation Acceleration;
  • Desktop: Roman Numerals example file included to the binaries archive for Mono;
  • Desktop: Font sizes toolbar drop-down list enabled for Linux version;
  • Desktop: Fixed issue with tall toolbar when latest versions of Mono used;
  • Behavior of numeric round(..) function changed to "round away from 0";
  • Behavior of trunc(..) function changed to "trunc closer to 0";
  • Fixed critical error of the Math region occurs on using "#" char in variables or functions names;
  • Error occurs when user uses infinity symbol as a part of variable/unit/function name fixed;
  • Underscore ("_") char is now visible in variables names;
  • Underscore ("_") symbol now can be used inside math regions;
  • Boolean operators priorities corrected;
  • importData(..) function improved to work with any of separators specified in options of the program;
  • Fixed issue with only partially shown grid of the Plot Controls;
  • Fixed issue when it was not possible to change background color of the Plot and Area Controls;
  • Fixed wrong Copy/Paste text data issues;
  • Fixed error when DELETE button parsed twice at once;
  • Fixed issues with wrong graphical representation of math expression (invisible brackets issue);
  • Fixed issue with not working trigonometric functions when user specifies Degrees as angles type in options;
  • Fixed simplification error: 0.75/abs(0.00003);
  • Fixed symbolic error with ln(..) and lg(..) functions: lg(1/{2*a}) -> lg(2*a);
  • Simplification error fixed: sqrt((1-a)^2)->1-a;
  • Fixed issue when numeric inverse trigonometric functions returns result with superfluous imaginary part;
  • Error occurs on numeric "inf^i" calculation fixed;
  • Function abs(..) improved in the numeric library;
  • Numeric calculation error of the sinh(..) function fixed;
  • Numeric calculation of functions acosh(..) and atanh(..) fixed;
  • Couple of errors with numeric infinities comparison fixed;
  • Critical error fixed, occurred when two or more users work with single on-page Control through the Teamwork Session;
  • Critical error fixed appears when loops are used in the right part of math expression;
  • Fixed critical error on opening file, created with a text control language, which is not installed in the target machine;
  • Language interface translations added: [SRP] Српски (Serbian Cyrillic), [RON] Română (Romanian), [BEL] Беларуская (Belarusian), [NOR] Norsk (Norwegian);
  • Language files updated;
  • Refactoring.
System requirements
  • Handheld:
    Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, WM 6.5, full VGA support, all PPC's, Comunicators and smartphones.
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop и Handheld (27 languages):
  • [ENG] English / English
  • [GER] German / Deutsch
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [SPA] Spanish / Español
  • [FRE] French / Français
  • [SCR] Croatian / Hrvatski
  • [SCC] Serbian / Srpski
  • [GRE] Greek / Ελληνικά
  • [TUR] Turkish / Türkçe
  • [CZE] Czech / Čeština
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [POL] Polish / Polski
  • [IND] Serbian Cyrillic / Српски
  • [IND] Romanian / Română
  • [IND] Norwegian / Norsk
  • [RUS] Russian / Русский
  • [BUL] Bulgarian / Български
  • [LTH] Lithuanian / Lietuvių
  • [UKR] Ukrain / Українська
    Free Download
    ** For installation of the program from PC it is necessary to install MS ActiveSync first.
    Tutorial
    Other files
  • 1 users liked this post
    cos_phi 7/23/2010 3:12:00 PM
    #2 Posted: 8/14/2010 1:44:41 PM
    Maxx
    Maxx
    1 likes in 8 posts.
    thanks! great job my friend.
    -maxx
    #3 Posted: 8/24/2010 8:05:12 PM
    Glad to inform, that SMath Studio Portable 0.89 was tested and certified by softpedia.com team.
    "Softpedia guarantees that Portable SMath Studio 0.89 Build 3856 is 100% Clean, which means it does not contain any form of malware, including but not limited to: spyware, viruses, trojans and backdoors."
    (details)
    #4 Posted: 9/29/2010 8:12:09 AM
    Felipe Cordero
    Felipe Cordero
    0 likes in 1 posts.
    Thanks! this piece of software is very useful for me.
    Felipe.
    #5 Posted: 10/26/2011 5:09:38 AM
    gsoffer
    gsoffer
    0 likes in 1 posts.
    Wow! well done! looks promising :-)
    I will love to work with it in parallel with my Mathcad in order to test it.
    Any planes for an Android version? I don't think you have any compatitors there...
    #6 Posted: 10/27/2011 4:11:03 PM
    sinclair
    sinclair
    0 likes in 2 posts.
    I love this piece of work too, for my windows smartphone HTC HD2,
    my question is, wether there was some progress in development of free? import tools to read in MATHCAD mcd files;
    would be happy when someone could write a short resume, how-to-do, for the actual state,
    much thanks
    #7 Posted: 11/7/2011 2:44:43 PM
    Jens Præst
    Jens Præst
    0 likes in 3 posts.
    Just got it on my windows notebook, and getting it on my linux stationary, but can I get it on my android (HTC desire S) whitout spending $399?????
    was trying to get the linux version, but cant get to download mono, just filling in forms
    #8 Posted: 11/12/2011 2:03:42 AM
    Glad to introduce a new help document for beginners who makes first steps using SMath Studio:
    SmathPrimer.pdf is in-part a compilation of existing documents (edited as I saw fit) plus some of my own work. I tried to cover all the problem I had as I started to learn SMath. It is primarily for people who are new to SMath and would like some notes all in one place.
    Document added to the main download page:
    Many thank to Bernard Liengme for his great work!
    #9 Posted: 11/12/2011 3:28:56 AM
    Optusprime
    Optusprime
    2 likes in 33 posts.
    Fantastic news for new SMath Studio user's thanks Bernard, and all the SMath Studio developers. Well done!
    #10 Posted: 12/13/2011 3:58:12 PM
    325 likes in 2052 posts.
    Many thanks to Marijan Dizdar for the Tutorial for Beginners in Serbian
    SMath priručnik
