X-Y Plot Region
X-Y Plot Region - Extends SMath Studio with a X-Y Plot Region. - Сообщения
#1 Опубликовано: 26.04.2013 09:20:32
X-Y Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
2018-12-21_13-32-23.png 2018-09-24_12-55-34.png XYPlot. Examples.png 2018-12-22_16-15-43.png 2018-08-03_08-25-36.png 2018-10-01_17-51-54.png 2021-11-17_00-50-10.png 2021-11-17_00-50-29.png
XYPlot. Examples.sm (30,04 КиБ) скачан 3859 раз(а).
XYPlot. Examples.pdf (154,55 КиБ) скачан 2892 раз(а).
XYPlot. Demo.sm (5,5 КиБ) скачан 2810 раз(а).
XYPlot. Demo.pdf (45,63 КиБ) скачан 2147 раз(а).
XYPlot. Text labels.sm (10,1 КиБ) скачан 2813 раз(а).
XYPlot. Text labels.pdf (53,78 КиБ) скачан 1812 раз(а).
XYPlot. Fill area.sm (10,03 КиБ) скачан 2618 раз(а).
XYPlot. Fill area.pdf (84,35 КиБ) скачан 1591 раз(а).
XYPlot. Draw shapes.sm (19,85 КиБ) скачан 3142 раз(а).
XYPlot. Draw shapes.pdf (92,91 КиБ) скачан 2141 раз(а).
XYPlot. Linear polar.sm (56,78 КиБ) скачан 2463 раз(а).
XYPlot. Linear polar.pdf (134,78 КиБ) скачан 1543 раз(а).
3D plots in XY Plot plugin
pMesh.sm (244,1 КиБ) скачан 2518 раз(а).
pMesh.pdf (3,04 МиБ) скачан 1970 раз(а).
Functions for grids, meshes and plot surfaces. Support triangular meshes and multiple surfaces in the same plot.
pSurf.sm (315,64 КиБ) скачан 2270 раз(а).
pSurf.pdf (2,2 МиБ) скачан 1710 раз(а).
Small piece of code for filled 2-D contour plot in the XY plot plugin.
FillContour.sm (34,45 КиБ) скачан 2373 раз(а).
FillContour.pdf (306,44 КиБ) скачан 1655 раз(а).
Note: '~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot.
Click to enlarge Click to enlarge Click to enlarge
XYPlot.%20Parametric.sm
Links:
1. Dr. Xu's Books .
2. Creating charts & graphics without coding .
17 пользователям понравился этот пост
Oscar Campo 26.04.2013 09:38:00, frapuano 03.12.2016 09:11:00, Mark R Harris 29.08.2022 07:50:00, sergio 13.01.2024 04:42:00, Radovan Omorjan 26.04.2013 10:32:00, Infinity 29.04.2013 03:12:00, ioan92 25.05.2025 13:21:50, ruddy 24.09.2025 00:30:07, Valery Ochkov 29.10.2025 15:15:21, Fridel Selitsky 26.04.2013 10:29:00, Davide Carpi 26.04.2013 10:12:00, Martin Kraska 26.04.2013 09:39:00, IVR 13.07.2013 05:09:00, yajurito 11.12.2017 17:33:00, Andrey Ivashov 22.09.2021 08:49:00, zoom 17.01.2016 17:14:00, maria 02.05.2025 03:56:13
#2 Опубликовано: 26.04.2013 09:38:29
Здорово!
I tried some functions (typed to the placeholder):
x - nothing happens
sin(x) - works
ln(x) - crash (perhaps due to undefined values)
any undefined function - crash
previously defined function returning a list - GUI freeze
#3 Опубликовано: 26.04.2013 10:23:34
Nice work uni
You can change only the function for now. Need to figure out a way how to pass parameters to display the graph or do it like in Mathcad.
A way could be to use context menu items (see ConstructorRegion plugin by Andrey)... also the Mathcad mode it's quite interesting...
you can post the plugin code?
#4 Опубликовано: 26.04.2013 10:46:39
This is a long time waiting feature and I think we are all excited about it
Good luck uni
EDIT: I tried it a bit in a "faulty" Mono in Xubuntu. It si working initially although with crashes as Martin mentioned
#5 Опубликовано: 26.04.2013 10:47:33
The code is taken from this book:
C# Application Series - Xu J. - Practical C# Charts and Graphics [2007, PDF, ENG] (link, rus).
I have something removed and added something to get the plugin. I added sources.
mkraska, not so fast Try some number.
Davide Carpi 26.04.2013 10:52:00, ioan92 22.07.2013 05:38:00
#6 Опубликовано: 26.04.2013 11:02:04
Thank you very much both for the sources and the book
[EDIT] plugins on wiki updated
#7 Опубликовано: 26.04.2013 11:45:46
kilele
kilele
thank you very much uni!
please look at this post:
http://en.smath.info/forum/yaf_postsm9105_Plots-improvements.aspx#post9105
ZedGraph is c# targeting .net20 so it should work both in windows and linux.
#8 Опубликовано: 26.04.2013 11:56:51
Basile
Basile
Thank you uni.
This is long overdue.
As you develop it, please have in mind the basic form of axes: Lin-Lin, Lin-Log, Log-Log.
Basile
#9 Опубликовано: 26.04.2013 12:45:04
...Try some number.
#10 Опубликовано: 26.04.2013 15:22:17
Basile
Basile
Radovan,
How did you put graph title and axis titles? and axes greater than 1.
Thank you,
Basile
#11 Опубликовано: 26.04.2013 15:58:45
Updated. Form formatting is added to the context menu. Changes take effect after the recalculation. You can use system for several functions but be careful (not tested yet).
Davide Carpi 26.04.2013 17:09:00, Radovan Omorjan 26.04.2013 17:01:00
#12 Опубликовано: 26.04.2013 16:39:18
Hello Basile
I did nothing else just put a number in the function placeholder, as uni said. It seems that uni just put this example just as a test at the moment.
Lots of user feedback in quite a short time shows that we are very interested in this plugin. It seems that we need to have some more patience until the very appreciated plugin like this become more stable , and than to test it more carefully
#13 Опубликовано: 27.04.2013 02:14:52
kaka
kaka
1 сообщений из 25 понравились пользователям.
Thank you again.
Last update: XYPlotRegion_20130427.zip
Sources: https://smath.info/svn/public/plugins/XYPlotRegion/
#14 Опубликовано: 27.04.2013 05:54:43
Updated.
Radovan Omorjan 27.04.2013 07:07:00, sergio 27.04.2013 09:25:00, Martin Kraska 28.04.2013 03:04:00, Fridel Selitsky 27.04.2013 07:16:00, Davide Carpi 27.04.2013 06:43:00
#15 Опубликовано: 28.04.2013 01:49:03
pol1
pol1
Thanks.
The traces & Number Format function is not working for me (Win 7 64 Bit).
#16 Опубликовано: 28.04.2013 03:01:32
Updated.
The last update seems to focus on handling lists of plots. The plugin seems to be under heavy construction.
For plotting functions, the xyplotrregion just evaluates the name, without caring for the argument, therefore plotting pure expressions just as x or x^2 fails.
Also, numbers must be pure numbers, not expressions that can be evaluated to numbers.
I guess that the built-in demo shows sort of development target. It would be interesting to know if expression input for plot items and range limits including unit handling are on the agenda. Anwyway, I am looking forward to the next release.
#17 Опубликовано: 28.04.2013 06:13:01
Thanks.
These tabs will be added later. Working on it.
Updated.
Radovan Omorjan 28.04.2013 08:00:00, Davide Carpi 28.04.2013 07:49:00
#18 Опубликовано: 28.04.2013 08:48:50
Updated.
Crashing xyplot:
- loading documents created with earlier versions of the plugin
- expressions evaluating to lists but not being lists (e.g. [MATH]±1[/MATH])
Not crashing xyplot:
- using units
empty placeholder produces a line y=x
Is using limit expressions including units (perhaps using placeholders as in old mathcad) on the agenda?
#19 Опубликовано: 28.04.2013 10:32:00
There is only one placeholder, so I can enter only the expression and nothing more. I don't know whether it is possible to add more placeholders. Limits for the graphs need to be set explicitly (in the formatting dialog).
#20 Опубликовано: 28.04.2013 12:26:50
Could global variables be an option?
The user might define or display values of settings like
XYPlot.xmin:0
XYPlot.xmax:3'm -> this would give the independent variable a unit
XYPlot.ymin:0
XYPlot.ymax:"auto" (auto-scaling)
XYPlot.xaxis:"log" or "lin"
XYPlot.title:num2str(n)
XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required.
Settings in the context menu might change or override the variable values or restore them to defaults.
Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
Radovan Omorjan 03.06.2013 07:24:00
