Tutorial
Tutorial - Creating Plugins - Сообщения
#1 Опубликовано: 27.04.2019 21:27:53
MAM64
MAM64
Are there plans for releasing of a "Symbolic expression evaluations" tutorial?
#2 Опубликовано: 28.04.2019 00:01:01
IMHO too much like re-writing Bible.
1000's demo ... show your expression/formula.
#3 Опубликовано: 28.04.2019 00:43:07
MAM64
MAM64
I would like to write the nabla vectorial operator, in order to get gradient, divergent and rotational operators.
#4 Опубликовано: 28.04.2019 06:09:32
Maybe... I have some technical issues ATM, so I can't really plan it for the near future.
If you want to give a try to low-level evaluation, about the math you might start from the gradient already coded here. To dress it, you can see this (that if you have the plugin installed should already works if you create your own 1 or 2 arguments function in a worksheet and you call it grad)
#5 Опубликовано: 28.04.2019 08:48:49
Borrow from here.
Maths Grad_Div_Curl_Jacob.sm (41 КиБ) скачан 149 раз(а).
sergio 28.04.2019 13:48:00
#6 Опубликовано: 28.04.2019 16:04:45
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 сообщений из 1676 понравились пользователям.
Hi. Maybe you found useful this post: https://en.smath.com/forum/yaf_postst16005_Grad--Div-and-Curl-in-a-curvilinear-coordinate-system.aspx
#7 Опубликовано: 28.04.2019 20:05:00
MAM64
MAM64
Borrow from here.
Thanks a lot!
