PDF Files Plugin failed to install
PDF Files Plugin failed to install - Any way to get it to work? - Сообщения
#1 Опубликовано: 28.03.2019 12:03:27
Daniel Jackson
Daniel Jackson
1 сообщений из 17 понравились пользователям.
I've tried installing it through the extension manager, and downloading it through my browser (followed by drag'n'drop), but I still can't get it to work. Anyone know how to fix it? I can reproduce the error quite effectively, so it's not just a one-off glitch. It just says "Plug-in failed to install" with no explanation as to why.
#2 Опубликовано: 28.03.2019 12:33:48
Arie
Arie
What version of SMath are you running?
#3 Опубликовано: 28.03.2019 13:37:23
So many things fail from version to versions.
IMHO, Smath does not need PDF plugin.
As fast as nice ... Print as => CutePDF => Document ID
Redox.pdf (73,07 КиБ) скачан 770 раз(а).
#4 Опубликовано: 28.03.2019 14:02:57
Daniel Jackson
Daniel Jackson
I know I could use an external PDF maker/editor, but I want to try and get this plugin working. Here's what I get at startup:
PDF Files Plugin (Version 1.0.6953.23116), Size: 23.95MB
Method not found: 'Void SMath.Controls.RegionsList..ctor (System.Collections.Generic.List`1, SMath.Manager.ContentPlacement)'.
Not sure what that 2nd line means. I have Smath Studio 64-bit, version 0.99 (build: 7005), 3/7/2019.
#5 Опубликовано: 29.03.2019 02:55:40
PDF plug-in was updated to work with 7005 correctly right after latest SMath Studio release.
You said you have PDF Files Plugin version 1.0.6953.23116 which is an old one (and it is incompatible with latest stable SMath Studio release).
It looks like you are using outdated version of the plug-in. From what you are saying it seems that more then one PDF plug-in installed on your system, so I could suggest to remove all versions of PDF plug-in first (it can be done using Extensions Manager - select a plug-in and use small Delete button at the bottom of the dialog). After plug-in deleted restart the app and check for PDF plug-in again. Do delete it again if it is shown in the list.
As soon as you see plug-in is missing in the list of installed ones try to install it again using Extensions Manager.
Hope this will help you. Note: plug-in works ok on fresh SMath Studio installation.
#6 Опубликовано: 30.03.2019 11:57:57
Daniel Jackson
Daniel Jackson
I went to the %AppData%\Smath\extensions\Plugins folder, searched for the extension, then deleted the folder that contained it. After that, I started Smath, dragged the zip file (Version 1.0.7016.41831) to it, and got the same exact error (Plugin installation failed), as well as the error I mentioned above (Method not found...). I've tried multiple times and it still doesn't work.
#7 Опубликовано: 30.03.2019 15:35:37
Install and delete plugins only via extension manager (tools> plugins). Never mess directly with files in the extension directory unless you know what you are doing.
#8 Опубликовано: 31.03.2019 09:53:36
The painless way to install and remove extensions is to use the graphic interface (extensions manager). If you act manually (folders manipulation) you have to be very careful, especially if you are not running the latest version (that is the beta actually), because plugins newer than the program might not work depending on the core changes, hence you have to pick the right one (the one showed by the extensions manger, that filter out the extensions made for more recent versions); I guess that to reduce issues for drag&drop users, the minimum program version should be shown in the extension page.
As for what I can see from the Extensions Manager the latest plugin version for the stable SMath Studio (0.99.7005) is the one that caused you the warnings initially (1.0.6953.23116) and seems working to me.
Close SMath Studio, go again into the %APPDATA%\SMath\extensions\plugins directory and delete the whole folder ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc, then open again SS. If no error are shown, go to Tools > Plugins [Online Gallery] and install again the plugin. If you have to do manually because no internet connection, download the version 1.0.6953.23116
#9 Опубликовано: 31.03.2019 11:58:32
Daniel Jackson
Daniel Jackson
It worked this time. I'm not sure why, but I think my AV (Avira) was blocking it. I'll try adding the ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc folder to my exceptions.
#10 Опубликовано: 31.03.2019 12:29:30
IMHO, what is the need for AV ? Since almost 4 years Smath runs on my
small laptop, Win 7 takes care of what could damage Win. NO AV of any kind.
No bug/problem, but try to avoid HTTP ... HTTPS is more secure.
True: my laptop is virgin of anything else than Smath.
#11 Опубликовано: 31.03.2019 13:06:52
NDTM Amarasekera
NDTM Amarasekera
I too had a similar problem in installing some plug-ins a few months ago.
After configuring the AV, the problems were solved.
https://en.smath.com/forum/yaf_postsm51419_-Plug-in-s--installation-failed--error.aspx#post51419.
#12 Опубликовано: 31.03.2019 13:09:56
Glad it is solved :-)
Nowadays threats might comes from everywhere (I've read recently of malicious code encoded and carried in pixels of advertising banners...); of course the main antivirus should be the one between the keyboard and the screen, but having some additional layers of security, f.e. windows defender, it's much better.
p.s. https means that the communication between you and the server is encoded and less vulnerable to man-in-the-middle attacks (and more private), but doesn't prevents to load malicious code.
#13 Опубликовано: 31.03.2019 17:13:15
Davide: you can't be more right, most appreciated, thanks.
That reminds me, at least 20 years ago, about the champion killer.
*.zip were also vulnerable. Before opening anything, open the
Fred Langa rubrique. He said the "killer" would be so effective that
hovering the cursor over the name ... zap.
I'm aware of the pixel be potential infectious, just read visited sites.
In what world are we leaving ? In fact, the prediction 2012 end of the
world makes sense as it goes hay wild in many directions.
Champion killer started by "N......"
