1 страниц (3 вхождений)
Native Windows 10 Application has no menus - Trouble using native Windows 10 app - Сообщения
#1 Опубликовано: 01.09.2019 11:57:31
Hello.
I installed and tried to use the Windows 10 native application found in the Microsoft Store.
It has no menus, nothing happens with secondary mouse click.
Ctrl, Alt, Shift key combinations does nothing.
Double click zooms in, and I did not found a way to zoom out.
Clicking to close the application does not ask to save for changes.
There is no save current document command, just save as...
Is there a way to make the menus appear in the windows 10 native application?
Greetings from Paraguay.
Claudio Bogado Pompa.
#2 Опубликовано: 01.09.2019 12:07:29
Claudio, do you mean Smath/Win 10 don't work ?
This Forum is dedicated to Smath mostly.
Often, collabs doctor other request.
Cheers, welcome to Smath Community.
#3 Опубликовано: 01.09.2019 12:14:14
What I tested that worked:
Typing variable definitions.
Typing text blocks.
Evaluating expressions.
I see that there is a windows 10 installer to be downloaded from another site.
I am using right now a computer that I can not install any software outside the Microsoft Store.
I downloaded the android version and it is essentially works the same, having the touch gestures to pan and zoom.
I guess the Windows 10 native App is designed to touchscreens only.
Typing text blocks.
Новые сообщения
Нет новых сообщений
