Arithmetical and Geometrical tools
Arithmetical and Geometrical tools - better understanding - Сообщения
#1 Опубликовано: 07.04.2021 08:34:44
jtm2020hyo
jtm2020hyo
1 сообщений из 10 понравились пользователям.
can we have Arithmetical and Geometrical tools?
always when a math software is created always focus on the algebraic part, but always forget Arithmetical and Geometrical, now that SMATH is my favorite software I wish to more tool like this.
#2 Опубликовано: 07.04.2021 09:27:29
can we have Arithmetical and Geometrical tools ?
Geogebra is freeware from former Mathcad Collab Steen.
Very specialized Geometrical. Smath does same and more.
Smath is more a CAS than Geometrical.
PentaStar.sm (11,59 КиБ) скачан 1554 раз(а).
#3 Опубликовано: 07.04.2021 13:14:18
jtm2020hyo
jtm2020hyo
Is there anything for Arithmetical tool?
#4 Опубликовано: 07.04.2021 14:14:59
Is there anything for Arithmetical tool ?
Sorry, I don't understand what is Arithmetical tool.
Besides spooling to file [store/recall], logic, computing machinery
perform a single arithmetic operation [+ ... add]
then subtract, multiply ... division is another story.
In short, in the simplest and the most advanced operating system(s)
their arithmetic is limited to [+, -, *, /].
All mathematical functions make savant combination of these 4 Aops.
Aops => [Arithmetic operations].
A good lecture: Semi Numerical Algorithms [Donald Knuth].
Can you be more explicit ?
#5 Опубликовано: 07.04.2021 17:47:40
jtm2020hyo
jtm2020hyo
Here a sample, operations with binaries PR another base different to 10
https://en.smath.com/forum/yaf_postst20220_operations-with-base-different-to-10.aspx
For example, for binaries:
2 in base 10 = 2
2 in base 2 = 10 ( base 2)
2 in base + 2 in base 2 = 100 (base 2)
4 in base 10 = 100 in base 2
Another example, calculate how many number with the way abca exist?
abca is a unique number and each variable represent a different figure
Example
abca
1231
1031
2452
Where
a is the number in the column 1 and 4
b for column 2
C for column 3
And like this exist lot
#6 Опубликовано: 08.04.2021 10:33:17
Another example, calculate how many number with the way abca exist ?
Something like this ?
Maths Binomial Notation.sm (80,75 КиБ) скачан 1547 раз(а).
#7 Опубликовано: 08.04.2021 12:57:01
jtm2020hyo
jtm2020hyo
not sure if permutation formulas apply here, but some samples here:
in this example, we can appreciate that any base different to 10 can be used in any operation, I mean Smath could add this feature to change the numerical base to be used anywhere. this is useful, for example, when we wish to convert 100 seconds (base 10) to a sexagesimal base(base 60) and for this we could simply change the base without doing any trick.
in Spanish:
related to the second sample/request, I did not found English documentation. here the translation:
Цитата
Combinatorial method
the amount of numbers or combinations that can be formed with several orders or variables independent of each other, is numerically equal to the product of the amounts of values ​​that can take orders or variables
this means, translated to SMath code, generate a matrix for each number, and we multiply the number of values, in the sample we have base 10.
in the sample above the solution is 4*10*5 = 200
edit:
... and the correct form to write a unique number with 3-digit is:
we have not this symbol in SMath.
edit 2:
... and the correct form to write a unique number with base different to 10 is:
we have not this symbol in SMath, but similar is the subscript.
#8 Опубликовано: 09.04.2021 09:55:58
Smath gets its productive power from zillions of utilities.
As applicable to projects, they are collected/collapsed at top of document.
The DMS(data) is one of those {Martin] as appropriate to your project.
Maths Convert [deg, min, sec].sm (9,67 КиБ) скачан 1333 раз(а).
