Error while saving
Error while saving - Сообщения
#1 Опубликовано: 11.06.2015 09:04:25
Werner Beek
Werner Beek
Dear all,
Daily I'm working on my smath file. Since the latest changes I get the following error while saving:
"Unexpected end of file has occurred. The following elements are not closed: input, math, region, region, region, region, regions. Line 35237, position 18."
The programm closes and the saved file cannot be opened any more. Does anyone know a solution?
Thanking you in advance,
Werner
#2 Опубликовано: 11.06.2015 20:11:39
You can (partially) fix the file by closing the missing xml tags (using a text editor).
To find the cause and fix the issue a reproducible sequence of actions or the file is needed (you may contact directly the developper if the file can't be shared here)
ioan92 12.06.2015 04:08:00
#3 Опубликовано: 12.06.2015 04:02:49
Hello Davide,
Is there any way that someone can write a Recovery script which will fix the broken SMath file. I remember that I found long time ago some similar script for the corrupted Mathcad files.
ioan92 12.06.2015 04:08:00, Davide Carpi 12.06.2015 07:54:00
#4 Опубликовано: 12.06.2015 07:49:13
I think is possible. Tomorrow I'll try to do something.
Radovan Omorjan 12.06.2015 08:11:00, ioan92 12.06.2015 08:20:00
#5 Опубликовано: 17.06.2015 07:16:14
Werner Beek
Werner Beek
Dear all,
I installed the latest nightly build version of Smath and since then I cannot reproduce the error any more.
