1 страниц (10 вхождений)
Fractal Tree - a programme for displaying a fractal tree - Сообщения
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7,93 КиБ) скачан 1197 раз(а).
fractal tree.pdf (209,83 КиБ) скачан 745 раз(а).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Thank you
Gerard Bush
Davide Carpi 16.03.2020 12:19:00
WroteI would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Like this ... in ½ points.
fractal tree.sm (11,31 КиБ) скачан 1186 раз(а).
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17,6 КиБ) скачан 1139 раз(а).
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18,39 КиБ) скачан 1137 раз(а).
Cheers,
Gerard
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12,54 КиБ) скачан 1134 раз(а).
Davide Carpi 16.03.2020 12:19:00, Alvaro 17.03.2020 16:15:00, Вячеслав Мезенцев 16.03.2020 13:59:00, frapuano 16.03.2020 09:35:00, Gerard Bush 16.03.2020 10:55:00
WroteThat is just what I was looking for.
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11,2 КиБ) скачан 1144 раз(а).
Pattern Frieze Heppi.sm (11,97 КиБ) скачан 1167 раз(а).
Pattern Hilbert.sm (8,53 КиБ) скачан 1118 раз(а).
Pattern Patch Work.sm (10,92 КиБ) скачан 1147 раз(а).
Pattern Fractal Sierpinski.sm (10,92 КиБ) скачан 1181 раз(а).
Pattern Snail.sm (26,85 КиБ) скачан 1164 раз(а).
Pattern Fern.sm (19,4 КиБ) скачан 1170 раз(а).
Pattern Sierpinski Kover.sm (16,72 КиБ) скачан 1155 раз(а).
Pattern Etoile Magic [Short].sm (46,69 КиБ) скачан 953 раз(а).
Pattern Sierpinski Triangles.sm (35,21 КиБ) скачан 1141 раз(а).
Pattern Prototile.sm (116,5 КиБ) скачан 1200 раз(а).
Pattern PythagorasTree.sm (6,99 КиБ) скачан 1176 раз(а).
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11,03 КиБ) скачан 954 раз(а).
Gerard Bush 18.03.2020 09:56:00
Thank you very much, Jean and Ber7 for your additions!
Davide Carpi 18.03.2020 15:07:00, Gerard Bush 18.03.2020 16:59:00, NDTM Amarasekera 19.03.2020 06:03:00
