If one presses the left mouse button while dragging then elements in the calculation sheet are selected as is usual in Windows Applications.
Would it be possible to change this mouse mode in such a way that when the Ctrl Button is pressed too, that the elements that in the way of the drag direction are moved in the direction of the dragging.
Example: (1) I put the mouse cursor at a certain position in the calculation sheet above 20 Elements, (2) I press Ctrl and the Left mouse button and drag the mouse cursor 200 pixel to below, (3) the 20 Elements are "pushed" below by 200 pixel.
This is a feature that is standard in Labview and is highly practical and makes a lot of sense for Smath especially in very large calculation sheets.
