Nightly build: SMath Studio 0.97.5283 (19 June 2014)
Nightly build: SMath Studio 0.97.5283 (19 June 2014) - Сообщения
#1 Опубликовано: 18.06.2014 18:27:09
2270 сообщений из 3734 понравились пользователям.
Nightly build: SMath Studio 0.97.5283 available
Latest changes (against SMath Studio 0.97.5280)
  • SS-143: Freezing of the application fixed on some copy/paste operations;
  • Fixed removing of Regions based on RegionHolder when placeholder is empty;
  • Fixed issue when useless brackets appeared between operands;
  • Insert Unit dialog improved to allow displaying properties as dimensions if defined.
Download
Davide Carpi 18.06.2014 19:29:00, Mikka 19.06.2014 00:10:00, sergio 19.06.2014 13:55:00, IVR 20.06.2014 08:49:00, Radovan Omorjan 21.06.2014 06:21:00, Вячеслав Мезенцев 21.06.2014 06:39:00, ioan92 21.06.2014 08:36:00
#2 Опубликовано: 21.06.2014 06:10:27
1222 сообщений из 2150 понравились пользователям.
The new version affects the image region, see issue SS-165. Are there changes required by design or is that an unintended collateral effect?
#3 Опубликовано: 23.06.2014 03:40:13
1402 сообщений из 1708 понравились пользователям.
Andrey, method UnitInfo.GetCurrentUnitName() was removed from ioman.dll (SMath.Manager.UnitInfo class) and what to do now? It was used in the include plugin.
EDIT: UnitsManager.GetCurrentUnitName() ?
#4 Опубликовано: 29.06.2014 15:37:36
Yes, it is correct.
#5 Опубликовано: 01.07.2014 12:33:26
Henrique
Henrique
1 сообщений из 17 понравились пользователям.
I can't download the file.
#6 Опубликовано: 01.07.2014 14:15:29
What file you can't download?
#7 Опубликовано: 01.07.2014 21:03:22
Henrique
Henrique
I can't download SMathStudioDesktop.0_97_5283.Setup.msi
it returns: Server Error in '/' Application.
#8 Опубликовано: 02.07.2014 03:17:48
Really strange, works for me (now and even yesterday)...
OS: Win 7 x64
Browsers: Chrome, Firefox, Firefox (using DownThemAll extension)
tried also using a proxy service (anonymouse.org)
Andrey Ivashov 02.07.2014 14:38:00
#9 Опубликовано: 02.07.2014 14:37:27
Thank you for the info!
Could you please try to download file again? I think I found the reason and just fixed it.
Please let me know about results.
Best regards, Andrey Ivashov.
Davide Carpi 03.07.2014 10:04:00
#10 Опубликовано: 02.07.2014 21:16:10
Henrique
Henrique
Now it works fine!
