[SS-3525] assigning element to matrix resets its size
[SS-3525] assigning element to matrix resets its size - matrix created artificially - Сообщения
#21 Опубликовано: 27.03.2018 23:01:33
Here you go Jean.
Is this a bug or a feature?
Mathcad shows this as a pread sheet [array,NOT vector.
is this a bug or feature.
Elsid,
Neither a bug, nor a feature. Your Mathcad snippet is NOT a spread sheet.
A spread sheet is typical of Excel, it has col/row identifiers.
Mathcad shows a display w/o col/row identifiers. It has many interesting
features that Smath does not have, mostly as local exploder for plotting.
You can plot erf(,) vs x directly. If you assign the project like we do
in Smath, Mathcad will display col/row in gray and you will plot row/col.
So, Mathcad display [not an assigned creation] ... NO col/row identifiers.
A Mathcad creation, i.e: an assigned creation ... col/row identifiers.
Many Mathcad Collabs asked about this distinction, I had a copy/paste reply.
All that explained, it would a great feature Smath distinguish a display by
some kind of non printable distinctive invention . For instance a damier
of little yellow/white squares [yellow lovely default Smath 255,255,225]
Array or vector.sm (30,85 КиБ) скачан 972 раз(а).
#22 Опубликовано: 28.03.2018 05:26:43
m227
m227
4 сообщений из 29 понравились и 1 не понравились пользователям.
Now check this (it is a part of a bigger calculation). If I use equal sign after assignment I get a matrix. If I try to get result again in next line, it magically renders to scalar.2018-03-28 10_23_45-SMath Studio - [sprawdzenie.sm_].png
#23 Опубликовано: 28.03.2018 10:23:01
Please: next time, attach the *.sm document
