Combobox Return Multiple Values
Combobox Return Multiple Values - Сообщения
#1 Опубликовано: 10.11.2022 02:27:14
Nick Kotichas
Nick Kotichas
Hello all,
I'm a new member of SMath. Im wondering if it is possible to use combobox to return multiple values from a matrix. Ive attached an image below as an example. If I select 7/16"_8d_6" O.C. I want to have both the 1500 and 15 value return without having to make multiple comboboxes.
Thanks!
#2 Опубликовано: 10.11.2022 02:45:12
Use a nested matrix.
multicombo.sm (4 КиБ) скачан 65 раз(а).
Davide Carpi 10.11.2022 06:31:00
#3 Опубликовано: 10.11.2022 06:40:50
You can also use ranged indices to pick any column you need listed in the order you prefer, without any change in the input matrix.
This is an example using either the item row or the item index
#4 Опубликовано: 11.11.2022 03:20:18
Nick Kotichas
Nick Kotichas
Thank you guys! This is exactly what I was looking for.
One more question if you don't mind. Is is possible to set the results to a different variable? For example. I want the 1500 value to be "vn" and the 15 value to be "Ga". This way the equations will make more sense if someone is reviewing them.
Thanks!
#5 Опубликовано: 11.11.2022 06:40:34
Like this?
#6 Опубликовано: 11.11.2022 14:01:42
Nick Kotichas
Nick Kotichas
Yes that is exactly it.
